NEED HELP!!!
Old Feb 8, 2015 | 10:15 PM
demo589's Avatar
Default NEED HELP!!!
I have a customer with a 96 Honda accord we replaced the stock vtech with another one out of a 93. My problem is I've timed it and retimed it again just to make sure but still won't start any ideas??????
Old Feb 9, 2015 | 12:26 AM
holmesnmanny's Avatar
Default Re: NEED HELP!!!
93 accords didn't come with vtec
96 accords have unadjustable ignition timing...timing is controlled by the ecu
Old Feb 9, 2015 | 12:31 AM
B20VtecVillain's Avatar
Correct, my guess is you are trying to use an improper ECU and it will not fire the engine you put in.
Old Feb 9, 2015 | 06:05 AM
djkurious's Avatar
Did you change the ECU?
Old Feb 9, 2015 | 12:39 PM
MAD_MIKE's Avatar
MM Gruppe B
'96+ USDM cars have a crank sensor on the oil pump housing.
'95- USDM cars do not.
If nothing else was changed and you only put an F22A* into a car that originally had an F22B1 post 95, the car will never start.
adams90crx@msn.com
May 31, 2011 11:15 PM
dspinz9747
Jan 27, 2009 04:55 AM
shoklid
14
Jan 15, 2009 09:10 AM
mani1
Jul 8, 2008 02:04 PM
gsrHB
May 4, 2006 07:58 PM
