My Snow Wheels are on... car pulls to the right.
Old Nov 3, 2002 | 10:07 AM
majeed11's Avatar
Default My Snow Wheels are on... car pulls to the right.
The car was aligned prior to the swap!
I never knew wheels/tires affect the alignment. only the balence. Is that true? Could it be just the air pressure in the tires? Or is there a chance I messed up the alignment when I removed the summer wheels?
Someone please advise,
Thanks in advance.
(wtf happened to by Avator? It disappered?)
Old Nov 3, 2002 | 10:12 AM
B94Cast's Avatar
Default Re: My Snow Wheels are on... car pulls to the right. (majeed11)
Are the snow tires that you put on new? Tread depth differences will produce symptoms like you are experiencing.
Old Nov 3, 2002 | 10:17 AM
majeed11's Avatar
Default Re: My Snow Wheels are on... car pulls to the right. (B94Cast)
oh no.. actually, let me clarify.. they not actually snow tires. They are tires off my friends civic... 14' steelies with all season GoodYears in the front, and Perellies (spelling?) in the rear. They are not new, looks like they have been used for a year or so.
You think this could be the problem?
I have to check the air pressure, what is the reccomened air pressure for the front and back?
Thanks for your help guys
[Modified by majeed11, 7:18 PM 11/3/2002]
Old Nov 3, 2002 | 11:17 AM
majeed11's Avatar
21 views, and just 1 reply ... come on guys
Old Nov 3, 2002 | 01:24 PM
Fuuma0083's Avatar
Have you checked the tread wear on it? If its used and from another car probably the tread on the tires are making you sway to the right.
Old Nov 3, 2002 | 02:36 PM
Jesse H's Avatar
It happens. Rotate the tires left and right or front to back and you'll see that it stops pulling to the right, may even pull the to the left.
Doesn't mean that the tires are bad, just not perfect.
Old Nov 3, 2002 | 03:03 PM
majeed11's Avatar
Default Re: My Snow Wheels are on... car pulls to the right. (Jesse H)
thanks dude...
I'll try that
EJ1 wilcox
Suspension & Brakes
Feb 28, 2006 06:27 PM
BrutalDawg
Oct 15, 2004 10:07 AM
Volcom
Oct 8, 2002 11:26 PM
