IL 2000 Honda civic hatch k24a2
For sale:
2000 Honda Civic dx hatchback
Miles: original 86,000
Second owner very clean chassis it started as an automatic and converted over to manual. I might have driven this car 20 times in the three years that I have owned it. Losing garage space need to sell.
Engine:
K24a2 very healthy motor leak down and compression tested this fall by Mikey @ Profunction
Stock internals
Stock head with new valve seals and lapped valves
Plm 4-1 header
Magnaflow race muffle
3" exhaust piping
Rbc manifold
Hybrid silicon intake
Ktuned fuel rail
Ktuned fuel pressure gauge
Aero motive fuel pressure regulator
Mishimoto radiator with -16 bungs
-16 coolant lines
Ktuned thermostat housing
Ktuned upper coolant housing
Ktuned billet oil dip stick
Ktuned billet oil cap
Ktuned coil pack cover
Ktuned billet shifter assembly
Ktuned a/c and P/s eliminator kit
Ktuned billet shifter cables
K-pro ecu version 3
Ktuned jumper harness
Hasport ekk2 black mounts
Eg subframe
Ktuned traction bar
New eg control arms with energy suspension bushings
Hard race compliance bushings
Blox competition full coilovers
Front spring rate 10k
Rear spring rate 12k
Blox upper control arm
New manual rack
New outer tie rods
Blox lower extended ball joints
Skunk 2 rear lower control arms
Asr rear subframe
Rsx Trans newer 1st and 2nd gear done by Profunction
Stage 4 sprung competition clutch
Findanza flywheel
New slave cylinder
S2k clutch master cylinder
Interior:
Memory fab carbon fiber drivers bucket seat
Memory fab carbon Kevlar passenger Bucket seat
Buddy club seat rails
Personal steering wheel
Aem gauges water temp, oil pressure,and air fuel ratio
Nrg short hub and quick release
Wheels:
15x8 Work Meister CR-01 3piece wheels. Have original boxs and registration and stickers for wheels.
Yokohama s drives with plenty of thread left.
Have a set of steel wheels with worn tires.
Rota wheels a pair with bfgoodrich drag radials has like a season left on them.
Plenty of other stuff that I forgot to mention
Made 220 hp and 178 ft by Mikey @ Profunction
The bad I can say is no heat or ac it is completely removed.
Call or text for more info. Perfect text before you call.
Car is located in Chicago
773-351-2874
titomontanez@att.net
Instagram @only1tito
Asking 7900 obo
Engine:
Stock internals
Plm 4-1 header
3" exhaust piping
Rbc manifold
Ktuned fuel rail
-16 coolant lines
K-pro ecu version 3
Eg subframe
Ktuned traction bar
New manual rack
New outer tie rods
Asr rear subframe
Findanza flywheel
New slave cylinder
Interior:
Wheels:
773-351-2874
Asking 7900 obo
