electrical?tranny?engine?....i dunno
Old Nov 3, 2002 | 09:32 AM
accord00turbo's Avatar
Default electrical?tranny?engine?....i dunno
friday night on my way home from work several different things started happening. 1st of all when my e-brake is engaged the lights that tell you a door is open comes on. 2nd my entire gauge cluster goes haywire, sometimes the rpm's will show sometimes it will just bounce up and down dramatically. 3rd the speedometer doesn't work at all, well it works up til i hit the smallest bump in the road. 4th my winshield wipers are slow as ****. last but not least, my car has broke down 2 times over the weekend, the lights will stop working, it makes a fast ticking noise when i try to restart it, so i automatically thought it was the battery and not the alternator. so i bought a new battery and thought everything was cool, til just a little while ago. EVERYTHING IS HAPPENING AGAIN. PLZ HELP
also i have a transmission problem. there is a chirping noise that gets faster the more gas is given and it disappears when the clutch in pressed in. when accelerating i have a grinding noise.
[Modified by accord00turbo, 10:34 AM 11/3/2002]
Old Nov 3, 2002 | 11:24 AM
Default Re: electrical?tranny?engine?....i dunno (accord00turbo)
ttt.
Old Nov 3, 2002 | 02:02 PM
RotaryBzzz's Avatar
sounds like your car was a "flood recovery". Was it? Electrical problems start popping up 6mo-1yr afterwards.
Old Nov 3, 2002 | 02:12 PM
Default Re: electrical?tranny?engine?....i dunno (RotaryBzzz)
nope, i bought it brand new off the lot, zero miles.
Old Nov 3, 2002 | 02:20 PM
RotaryBzzz's Avatar
i haven't really seen you in this forum so why don't you post your cars specs:
year
trim level (lx, ex, dx)
miles
tranny ever replaced? Last time had transmission fluid changed?
any front-end accidents?
any weird events....maybe driving into a flooded highway...something like that. This will help us pinpoint your problems...
Old Nov 3, 2002 | 02:27 PM
i'm in this forum all the time.
2000 lx, 50,000 miles. never had a front end collision, never had any problems with the tranny, had all maintenance checks done. i've never driven through a large body of water nothing. i baby my car, have used mobil1 synthetic since the day i bought it. my mods include: i/h short shift adapter.
i don't understand whats goin on cause there were no warnings that this was comming on. normally i can tell just by how my car accelertates how many miles to the next oil change, i mean i notice every little thing.
thanks in advance,
brian
Old Nov 3, 2002 | 03:44 PM
fcardoso's Avatar
Did you recently have an alarm put on or Sound equipment etc...
If done improperly could cause all kinds of strange things!!
Old Nov 3, 2002 | 04:30 PM
gogeeta13's Avatar
Default Re: electrical?tranny?engine?....i dunno (fcardoso)
Sounds to me like you are running a new audio system with a very shitty ground, everything you are saying describes the symptoms of a bad ground.
Old Nov 3, 2002 | 04:34 PM
Default Re: electrical?tranny?engine?....i dunno (gogeeta13)
nope no sound system or alarm work. i had couple twelves in the back but i had those professionally installed and removed when i sold them, that was also about 6 months ago. it has to be something else
Old Nov 3, 2002 | 06:52 PM
rrei's Avatar
did u install indugo gauges or mess with your dash and when the rpm's rise and fall does the engine surge also. also did u get an alarm put in recently. i dont remember if the e-break rests at ground or 12volt.
Old Nov 3, 2002 | 07:06 PM
Default Re: electrical?tranny?engine?....i dunno (rrei)
i haven't done any kind of work on my car about 6 months now. even when i did do some work it was never electrical.
Old Nov 3, 2002 | 07:14 PM
90H22's Avatar
When you had the sound system removed did they actually remove everything? I would make sure they removed all the wiring too. Sometimes they like to stash it under some carpet somwhere and that can cause problems.
Old Nov 3, 2002 | 07:19 PM
PnX-R's Avatar
You're saying that when you start your car, all you hear is a fast ticking noise.. If that noise is from the engine bay, it might be from your Starter Solenoid.. I don't know anything about Accords.. But I do know that if it's from your Starter Solenoid, that means that your Coils inside the Solenoid are not getting enough power.. It's kind of hard to explain..
But if that's the case, I'd have to say that something is causing a Hot to Hot Short.. And since everything that is happening is around the Cluster, my guess would have to be the Ignition Switch Module or the loose connections in or behind the Fuse Box.. I can't really give you an answer because I don't have a wiring diagram for a Honda Accord.. But Good Luck..
Old Nov 3, 2002 | 07:31 PM
Default Re: electrical?tranny?engine?....i dunno (PnX-R)
thanx i'll check that out. i also checked to see if the wire was removed from when my subs were taken out at it was gone. my engine doesn't really surge when the rpm's go up and down. the only thing that has occured similar to that is, today when she died on me was that she started to buck and sputter. the part that i can't figure out is why did the battery that i bought friday seem to alleviate all the problems i was having temporarily instead of not at all.
Old Nov 3, 2002 | 08:58 PM
fcardoso's Avatar
Because, it might be that you have a short somewhere in your wiring system and it drained the battery!!
Thus putting in a new battery help it for a little while until it starts draining the battery again!!
Maybe your old battery only needs to be recharged!!
Old Nov 3, 2002 | 09:10 PM
90H22's Avatar
A dead alternator will drain a battery in a hurry. Checked that?
Old Nov 4, 2002 | 06:29 AM
Default Re: electrical?tranny?engine?....i dunno (90H22)
how do u check for a bad alternator? should i just take it somewhere like autozone and have them check it for me? and, can someone tell me how much a new alternator will cost. sorry for all the questions, i barely have time to breathe between school and work. i appreciate all the help u guys have been.
Old Nov 4, 2002 | 02:22 PM
90H22's Avatar
Yea, it has like 2 or 3 bolts and you can just yank it off and carry it to any of those places and they'll hook you up, it's usually free. A new one is like $100 I think.
aubreylorraine
Mar 25, 2010 04:27 PM
turbow
Feb 5, 2005 03:23 PM
colombian linx
14
Sep 20, 2004 10:29 PM
yusoslo
Feb 26, 2003 06:27 AM
