what size tire should i get so i dont rub on fender
Old Feb 3, 2015 | 10:17 PM
KINGFLIP's Avatar
Icon2 what size tire should i get so i dont rub on fender
as the title says, i've been running 17" wheels on my 02 accord since i first got the car, i've always had low-pro tires (205/40R17). but as the tread is pretty much gone from my current ones, i've decided i want to go with bigger tires. but since this is the first time im doing this, i dont know how much bigger i can go without worrying about them rubbing on anything. anyone have any input on this?
Old Feb 4, 2015 | 05:06 AM
Fitz Williams's Avatar
10 Year Member
Default Re: what size tire should i get so i dont rub on fender
205/40 is pretty low. I run 215/45 on a Gen 5. Those come out to be about the same diameter as the originals. I think the Gen 6 V6 had slightly larger tires than that. What I did was to buy some cheap used tires and try them before I laid out the money for good ones. Also, a LOT depends on the rims you have.
Old Feb 4, 2015 | 08:17 AM
KINGFLIP's Avatar
i dont remember what type they are, but i know they are Redline. i went to the shop today and they had some used 225/55r17 but i think they are too big, i dont know how to find out though
that's what they look like
Old Feb 4, 2015 | 02:31 PM
chrisnick's Avatar
I'd stick to a 225/45/17. Lots of tires available in that size.
Old Feb 5, 2015 | 04:36 AM
10 Year Member
Most used tire shops around here will sell you a tire and mount if for $20. Pick a size, like the 225/45/17 and see how it does. You can take measurements from it and see what will and won't work. Also, there is a guy on the Wheel and Tire forum that can look at a rim and tell you what you have. He goes by toyomatt84. Try posting over there.
honda_andy
Nov 20, 2006 09:30 AM
doggworld1233
42
Mar 29, 2006 01:53 PM
accordselux
Mar 1, 2006 12:51 PM
azndng
Oct 18, 2005 12:59 PM
JohnnyBoy
Mar 16, 2002 10:05 AM
