No Crank position sensor
Old Feb 2, 2015 | 02:43 PM
Chevy33's Avatar
Default No Crank position sensor
I put an F22b1 obd1 engine in a obd2 system. Obd2 distributor exists now and the F22b1 engine I put in will not allow the installation for the crank position sensor/crank fluctuation sensor on the oil pump housing.
I would like to know if I can install another oil pump housing on this engine which can accommodate the sensors?
Old Feb 2, 2015 | 03:06 PM
holmesnmanny's Avatar
What year and engine model was the original engine ? You might be able to swap over your existing. Or you need a 96/97 f22b1 oil pump housing and crank/tdc sensor assembly. Only civics had the fluctuation sensors, yours will have a tdc sensor.
Old Feb 2, 2015 | 03:49 PM
Chevy33's Avatar
Default Re: No Crank position sensor
The original 1998 engine F23A4 engine went for a core so those parts are not available to me. I did retain the ckp/tdc sensors. I will be able to search for another oil pump cover and the necessary gear for timing from the salvage yard. Ebay has a pump cover listed which says fits a f22b1 and a few others. It says it fits a 2.2l and a 2.3l. I would like a conformation from someone who has made this swap.
Only issues I can have so far with this swap is no fire due to no ckp and the oil pan is touching the frame.
Last edited by Chevy33; Feb 2, 2015 at 04:10 PM. Reason: corrections and missing info
Old Feb 4, 2015 | 07:22 PM
GhostAccord's Avatar
It specifically has to be a 96-97 F22B1/B2 oil pump housing. And will you also need both timing belt and balance shaft crank gears.
Old Feb 9, 2015 | 04:30 AM
Chevy33's Avatar
Icon6 Re: No Crank position sensor
I did get an oil pump cover which would accept the two sensors. All is good and the engine is a good one? One thing left is to add a knock sensor.
Thanks for the help.
JusAccord
Nov 7, 2011 02:11 PM
patotas
Mar 26, 2009 06:30 AM
schlong1
Oct 19, 2008 05:38 PM
bigblockbuick
Sep 5, 2007 07:04 PM
MassScene
Dec 14, 2004 04:55 AM
