dr_latino999's 1990 Civic Sedan LX+ F/S - $1750
SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD
So I've had this car since 2002, and it's served me well as my backup car since I purchased my Evo in 2011, but it is time to part. Can't transport three cars in my upcoming move across the country
This was my first introduction to Autocross, took me across the country multiple times, and survived a long stint in South Florida as is; the chassis is at 227936 but I'd gladly put another 100k if I could. On to the modifications.
Engine / Transmission
- JDM D15B, installed in 2010, I've put about 7k miles on it.
- ACT HDSS clutch and pressure plate combo
- 91 CRX Si Cable Transmission, survived more engines than I can count, differential replaced in 2006.
- DC 4-1 Ceramic coated Headers
- D16Y8 Intake Manifold ported to match throttle body
- B18A1 Throttle
- Short ram intake with KN Filter
- Shaved / Painted valve cover
- NGK Wires and Plugs
- Factory Exhaust. Because I can.
- Fidanza Flywheel
- Innovate 75A Engine Mounts
ECU/Electrical
- OBD-0 - OBD-1 Hard Wire Conversion (Documented on Forum)
- Neptune Chipped ECU (TurboGixxer Tuning) running a D16Z6 Map
- PC680 Battery Relocated to trunk (Brand New)
Cooling
- Full Race Mini Radiator
- Slim fan that comes with said full race radiator
- Heater core is still installed
- A/C Deleted
- A/C Firewall Delete Plug
- EG Upper radiator hose
Suspension
- Koni Yellow / Eibach Springs
- Full Race Traction Bar
- Quaife Quick Ratio Steering Rack
- HF Rear Cross member
- Neuspeed front strut tower bar
- EX front Knuckles
- ARP Front Studs (Standard Length)
- DA Integra Rear Trailing Arms
- SPC Rear Toe Adjusters
Brakes
- Front Legend Calipers (Twin Piston)
- Redrilled Front 11.1" Rotors (Blanks)
- Cobalt Friction GT-Sports Front Pads
- Rear DA Calipers
- Rear DA Brembo Blanks
- Cobalt Friction GT-Sports Rear Pads
- StopTech Front Brake Lines
- Accord 15/16" Brake Booster
- DA Integra Brake Proportioning Valve
Interior/Exterior
- Rota Gunmetal Slips 15x6.5
- Falken RT-615s 205/50/15
- JDM Integra Type-R Steering Wheel (So comfortable)
- DA Integra Center Arm Rest
- EDM EF-2 Center Console
- OEM Replica Floor Mats
- Skunk2 Shift ****
- 88/89 Rear Center Reflector
- Faded 26 year old paint. But seriously 26 years old and not too bad other than standard clear coat issues.
Creature Comforts
- Power Windows
- No Power Steering - Chassis weighed in at 2040lbs last scale check
- No A/C - Survived 3 Summers in TX as a beater and 8 years in Florida...you'll be fine.
Here are links to the albums with ginourmous size images -
Album 1
Album 2
Here are the Thumbnails
Attachment 521231
Attachment 521232
Attachment 521233
Attachment 521234
Attachment 521235
Attachment 521236
Attachment 521237
This was my first introduction to Autocross, took me across the country multiple times, and survived a long stint in South Florida as is; the chassis is at 227936 but I'd gladly put another 100k if I could. On to the modifications.Engine / Transmission
- B18A1 Throttle
- Fidanza Flywheel
ECU/Electrical
Cooling
- A/C Deleted
Suspension
- EX front Knuckles
Brakes
- Rear DA Calipers
Interior/Exterior
- Skunk2 Shift ****
Creature Comforts
- Power Windows
Album 1
Album 2
Attachment 521231
Attachment 521232
Attachment 521233
Attachment 521234
Attachment 521235
Attachment 521236
Attachment 521237
dr_latino999
Feb 5, 2015 02:19 PM
FritzInTN
Dec 29, 2005 12:53 AM
