TN FS: 1991 Honda CRX Si Turbo
First off, I will not be using this web site to communicate, please see my listing on craigslist.com
1991 Honda CRX Si Turbo $7000 OBO
1991 Honda CRX Si Turbo. Heavily modified vehicle. I purchased this car in 2003 as a completely stock, unmodified vehicle and have built it up to where it is today over those years. In 2010, I purchased an engine and transmission swap kit from HMotorsonline.com and when I received it, I took the engine apart and built it the way it is now. Asking $7000 due to the cost of the extensive modifications. I am willing to work on the price a little. Don't lowball me if you don't have a concept of what these kind of auto parts cost.
Currently Equipped:
B16A engine
J1 transmission 5 speed manual
Wiseco pistons 9.0:1 compression
Eagle H beam rods
ACL Race rod and main bearings
Golden eagle block guard
ARP Head studs, Main studs, piston rod studs.
9 lb flywheel
6 puck ceramic clutch
Custom T3 turbo kit running 5-20 psi
RC Engineering 550cc injectors
2.5" exhaust
2.5" intercooler piping
Manual boost controller
Hondata S300 ECU
GM 3 bar map sensor
Innovate motor sports wideband AFR sensor/gauge
Skunk 2 slip on coil over system
Koni Sport yellow shocks
Energy suspension bushings installed in front suspension, rear bushings included but uninstalled.
Upper and lower balljoints replaced in 2014
Inner and outer tie rods replaced in 2014
Front hub bearings replaced in 2014
Rear hubs replaced in 2013
Front and rear strut tower braces
Front fender braces
Front traction bar
15x6.5" rims with 205/50R15 Nitto Neogen tires
Cloth top is removable in nice weather
Grant Steering wheel
Skunk2 double bend ball bearing shifter with matching weighted shift ****
I have all the missing interior pieces shown in the pictures and will be including those in the sale. I will update the pictures as I get them reinstalled.
Really fast car looking for the right owner to give it a little TLC to finish an already great project.
Odometer reads high because it was high mileage when I bought the car. Has less than 20,000 on the current engine.
Currently Equipped:
B16A engine
Eagle H beam rods
9 lb flywheel
2.5" exhaust
Hondata S300 ECU
GM 3 bar map sensor
Front fender braces
Front traction bar
vehicle is located in clarksville, tn. turbo is a .45 cold side, .48 hot 50 trim t3. If you are interested, I ask that you use craigslist to contact me because it makes it easier for me to organize and answer questions about the car. It's street tuned, and I just run 14 psi on it daily, so 8 estimate it's around 300 hp but I am not sure.
Honda_Fanatic
Oct 26, 2007 07:01 PM
Honda_Fanatic
Oct 25, 2007 08:23 PM
