front end rattle
97 civic dx
Trying to chase down a front end rattle over bumpy roads. Jacked up front end and have no movement at 12-6 but a shitload at 3-9. Question is can TREs that have enough movement that I don't feel safe driving rattle like a loose jamb nut on an adjustable control arm? I've ordered inners and outers because may as well but need to know if I should look elsewhere. Everything else has grease, boots are Good and have No movement when shaken.
Deff sounds like a suspension rattle?
I would inspect
Sway bar end links / sway bar bushings
Tie rod ends as you stated, I would also look at the struts. They've been known to make the rattle clunking noise when going over small bumps on the road. Good luck man
I would inspect
I don't see anything resembling a sway bar. Is that normal for a DX?
The DX doesn't have sway bars.
If you have a "shitload" of 3/9 movement, you have a problem with your tie rods. Isolate the problem, fix the problem, and make sure you get an alignment afterwards. Yes, a failing/failed steering component should be considered risky. The only other part of that specific system is your steering rack. Do you have excessive play in your steering wheel?
724chris
Apr 2, 2010 07:20 PM
