96 Accord coupe faint fuel smell in engine bay
Old Jan 26, 2015 | 10:25 AM
t_m's Avatar
t_m
Default 96 Accord coupe faint fuel smell in engine bay
Hey all,
My in-laws have a 96 Accord coupe what there seems to be a slight smell of fuel coming from the engine bay beneath the brake master cylinder. Can you give me an idea of what might be in that area that might be leaking? Thank you.
Old Jan 26, 2015 | 10:52 AM
therhett17's Avatar
Default Re: 96 Accord coupe faint fuel smell in engine bay
Originally Posted by t_m
Hey all,
The fuel filter is located below the master cylinder, might check that for leaks and the like.
Old Jan 26, 2015 | 11:37 AM
t_m's Avatar
t_m
I thought that was a fuel filter I saw under there. Thanks for the heads up. I can't be sure they ever changed it, so I'll grab a new one.
Old Jan 26, 2015 | 03:59 PM
Lost Again's Avatar
Don't just jump to the filter, verify first. If you've never changed one on a 5th gen you'll know why.
If you can smell it, you should be able to see the "wet gas".
Old Jan 26, 2015 | 06:14 PM
MAD_MIKE's Avatar
MM Gruppe B
Could also be an EVAP issue. On the firewall there will be three lines coming up from under the car. Primary will have the fuel filter, secondary will be the return fuel line(follow it from the fuel rail), and third will be the EVAP line. Verify that none of the vacuum hoses have been pulled off/damaged/etc.
Old Jan 26, 2015 | 09:58 PM
t_m's Avatar
t_m
Thank you guys. You guys are awesome. I'll grab a light and inspect those lines.
Twistedframe
Mar 15, 2022 05:43 PM
75aces
Dec 18, 2011 09:36 PM
taz4626
Feb 17, 2009 10:39 AM
thatasiankidtony
Aug 3, 2006 11:04 PM
fastaccord94lx
Apr 9, 2004 07:44 AM
