Em2 starting problems
Hi I recently drove my 2002 civic onto a car trailer to move it to another location it was running just fine then it cut off and hasn't started back up yet I have checked all fuses and the relay the fuel pump does not make any sounds when I turn the key but if I pour a little fuel into the throttle body it fires right up can anyone help thanks
If you dont hear the fuel pump relay coming on then theres your answer...you said once you pour gas into the throttle body it cranks?...so theres no fuel getting to the injectors...hence the fuel pump is not priming...smack the relay a few times see if it cuts it on...if still dont work replace bra!
superjet701
Jul 8, 2007 06:54 PM
Cameron60
Jan 16, 2007 06:04 PM
