Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Electical Issues / Headlights and interior light pulsating
Old Jan 25, 2015 | 10:18 AM
prodjay10's Avatar
Default Electical Issues / Headlights and interior light pulsating
2004 Honda Civic LX Coupe 1.7L Automatic
A while back the headlight and dome light started pulsating. I didn't do anything about it until the alternator died. I had a friend fix it. One of the brushes fell apart so he replaced it. Took it to Vatozone to test. Passed their test.
Car works fine for a while. I don't see any pulsating. But battery died right away too. So I get a new battery. After new battery is installed the lights pulsate again. It does this on and off. I can't seem to figure out what triggers it.
Soon after the turn signals stop working intermittently. Same with the dome light. Sometimes it doesn't want to work.
Anyone ever have this issue?
Any help would be appreciated.
Old Jan 25, 2015 | 10:43 AM
toyomatt84's Avatar
Sanji
Default Re: Electical Issues / Headlights and interior light pulsating
You may have a faulty multiplexer.
Old Jan 25, 2015 | 11:14 AM
prodjay10's Avatar
Is that the one next to the flux capacitor? jk
How would I begin to diagnose?
Old Jan 25, 2015 | 01:57 PM
toyomatt84's Avatar
Sanji
https://honda-tech.com/honda-civic-2...oblem-3234890/
Old Jan 25, 2015 | 04:47 PM
Former User's Avatar
Does the charging system warning light in the cluster sometimes turn on while you are driving?
Old Jan 25, 2015 | 05:04 PM
prodjay10's Avatar
The warning light doesn't come on. It did when the alternator went out.
Old Jan 25, 2015 | 05:13 PM
Turn the key from OFF to ON(II) without starting the engine. Does the charging system warning light in the cluster turn on and stay on? If so, start the engine. Does the light turn off?
Old Feb 28, 2015 | 10:15 AM
prodjay10's Avatar
The charge light comes on with key on engine off. And turns off after turning on engine.
Old Mar 1, 2015 | 03:29 PM
Check the G201 and G501 grounds. They are both shared by the Multiplexer and the turn signals.
Old Mar 7, 2015 | 12:59 PM
prodjay10's Avatar
G201 is behind the radio and G501 is on behind the right headlight mounted to the inside of the fender correct?
Just recently the cruise control and turn signals stopped working altogether.
Old Mar 8, 2015 | 05:37 PM
nikkarocky's Avatar
I know you said you replaced the alternator but the rectifier might be going out. I had the same issues with my gfs car and replaced it with a denso alt and everything is good as new now
Old Mar 8, 2015 | 07:50 PM
prodjay10's Avatar
I didn't replace alternator. I had it fixed by having one of the brushes replaced. The alternator has come to mind. I wonder if the test they perform at the auto parts store with the alternator in the car will tell if the rectifier is bad?
Old Mar 9, 2015 | 06:06 PM
prodjay10's Avatar
I went to autozone today. They tested alternator in the car. According to them, it works.
RonJ@HT, I'm having a hard time finding the location of those grounds. Do you happen to know where they are?
Old Mar 9, 2015 | 07:38 PM
Old Mar 12, 2015 | 06:26 PM
prodjay10's Avatar
Turns out the turn signals weren't working because of the turn signal relay. Swapped that out and the turn signals work.
Now to track down the other issues.
Old Mar 19, 2015 | 09:32 PM
Honda_Dude84's Avatar
ur alternators bad mine did the same thing, it charged barely at 12.2 to 12.4 volts and the ripple current was real bad due to a failing diode / rectifier. U should get the alternator replaced promptly. because I also had a new battery like u and my alternator was just sending enough "spikes" to keep it going and now I have to get both a new battery as well as an alternator cause the old alternator fried the cells.
Old Mar 20, 2015 | 04:15 AM
prodjay10's Avatar
Where did you get your alternator?
I'm not sure if I should go with new, used, or rebuilt. The used would hopefully be original parts which would be better quality, but may have the same issue as mine.
Old Mar 25, 2015 | 04:17 PM
Djratrap's Avatar
Are you running an aftermarket header?
Old Mar 25, 2015 | 05:02 PM
toyomatt84's Avatar
Sanji
What does that have to do with this topic?
Old Mar 27, 2015 | 10:46 PM
prodjay10's Avatar
Stock header...
Old Mar 29, 2015 | 05:22 PM
Djratrap's Avatar
The crappy aftermarket headers (megan specifically) tend to pinch the secondary o2 sensor wires (grounding them) causing all types of shorts. I've personally had it happen to my old 7th gen. Fried my ecu and shorted a bunch of stuff.
Old May 15, 2015 | 10:34 AM
prodjay10's Avatar
I replaced alternator with a used one from a junk yard. Looks like the issue is fixed. No more pulsating.
khmr270
Oct 31, 2022 01:01 PM
photostopper
Jul 7, 2009 12:58 AM
rclark
Jan 8, 2009 07:49 AM
civicsaremean
Jul 17, 2007 11:35 PM
Underwaterer
Apr 14, 2006 08:17 PM
