Disabling the automatic seatbelts of a 91 accord
Old Jan 24, 2015 | 08:42 PM
nstock's Avatar
Default Disabling the automatic seatbelts of a 91 accord
Does anyone happen to have thoughts on the best way to disable the automatic seatbelt feature on a 91 Accord (leaving them in the all-the-way-back position)? I was hoping there was simply a circuit breaker I could pull to do so, but it's unclear which one that would be, and what else would be disabled by doing so.
Thanks in advance for any suggestions!
Old Jan 24, 2015 | 09:11 PM
holmesnmanny's Avatar
Pull the relays in the engine bay fuse box.
Old Jan 25, 2015 | 12:50 PM
nstock's Avatar
Default Re: Disabling the automatic seatbelts of a 91 accord
After a little more research, I found out that the fuses labeled "R passive motor" and "L passive motor" refer the power seatbelts, so that should do it!
Old Jan 26, 2015 | 03:00 PM
kevinhughes13's Avatar
I went through this last year and here's what I found. The fuses to the automatic seat belts at-least in my 90 were linked to other electrical components so if you look under your passenger seat you'll see a black box turn your key on get them in the back position and unplug that and you should be good to go.
Old Jan 26, 2015 | 09:47 PM
nstock's Avatar
Great, thanks for the suggestion. I will go with that instead - sounds less likely to impact other parts of the car.
Old Jan 27, 2015 | 07:38 AM
Tachi's Avatar
I remember going through something similar on my 90 rx7, can CD seatbelts be retrofitted into a CB chassis?
bgoetz
Sep 4, 2007 08:34 PM
EGhatch33
Jan 30, 2007 07:42 PM
Dave R
Jul 5, 2003 05:54 AM
patastinky
Dec 3, 2002 12:09 AM
