1994 honda accord engine flooded with gas
Old Jan 24, 2015 | 04:16 PM
Dadragonlord289's Avatar
Default 1994 honda accord engine flooded with gas
hey everyone
I was working on my Honda Accord and for some reason the engine is flooded with fuel recently it flooded before and I just cleaned off the spark plugs in it just started up but now I'm cleaning up the spark plugs and its still flooded with fuel so how do I drain the excessive fuel in the engine?
Old Jan 24, 2015 | 04:33 PM
Digitalis's Avatar
Default Re: 1994 honda accord engine flooded with gas
Not sure about accords, just throwing my comment in here. In my Pontiac to deflood an engine, you start it at WOT.
Old Jan 24, 2015 | 06:21 PM
holmesnmanny's Avatar
Turn the key to on without starting the car. Hold the pedal down for five seconds. Then start it up.
Old Jan 24, 2015 | 06:33 PM
Is this a known method that works? because i don't want to flood the engine even more. im just very cautious since this is not the first time it actually flooded. more like the third time
Old Jan 24, 2015 | 09:15 PM
Fuel injected cars only flood if you have no spark. End of story.
Do whatever you want, it's your car.
Old Jan 24, 2015 | 09:48 PM
Only thing i asked was was if this method works.
I recently replaced the spark Plugs.
Old Jan 25, 2015 | 12:01 AM
Just because you have replaced the spark plugs doesnt mean you have spark, and that the spark is blue.
Old Jan 25, 2015 | 12:24 PM
Murphy84's Avatar
Normally pushing the gas pedal all the way to the floor shuts off the gas. You could try this while trying to start it but like someone said, make sure you have spark. You can get a spark tester pretty cheap.
Old Jan 25, 2015 | 03:17 PM
Its called "clear flood mode".
crook803
Nov 18, 2017 04:36 PM
Adro01982
Feb 29, 2008 06:36 PM
luketrot21
Nov 1, 2003 12:21 PM
