92 accord ex f22a6 stalling issue (help!)
I bought a 92 accord wagon ex about 6 months ago and from there on i changed spark plugs oil change obv. various suspension parts fuel filter alternator and a battery but besides the fact theres a problem with it stalling i started my car to go to work the one day and it started up and i came back out 5 mins later and it wasnt running so i started it again right after and it went idle for a bit and the a quick rev up from 1500 to 2000 but really fast and then it stalled so i unplugged the wire going tp the throttle body i think and then started it in netrual and then it was fine but almost stalled on me twice driving back home and then the next morning i started it it stalled and then i repeated it three times and after the third time it wouldnt start at all but the fuel pumps fine what could be the problem
Im not sure but would it start if it didnt have a spark because its been a while since i changed the plugs and it ran fine till now maybe i didnt gap it right but theres no cel besides the one when i unplugged the plug to the throttle body but i plugged it back in after and it went off the next morning could the spark plugs be flodded cause i do live in buffalo where its ten degrees out around this time of the year and im sometimes leave it running for 20 mins the one time accidentally
The last part of your post says the car won't start at all. I read that as the starter is spinning the engine over yet it won't fire up and run.....?
Clean the TB, clean and adjust the IACV and FITV if needed.
I'd also be sure the coolant level is ok.
Yes starters fine it just wont turn over after the third stall on the second morning and alright ill do that
