NJ 1995 Honda Accord Ex 5sp - $1500 NJ,NY,CONN
Old Jan 22, 2015 | 04:44 PM
swes2006's Avatar
Default 1995 Honda Accord Ex 5sp - $1500 NJ,NY,CONN
Selling my 1995 Honda Accord Ex 5sp 216k , Clean title in hand, Current NJ Inspection till April 2016 --- Asking $1500 Nice
Click Link for pics:
PROS--Many New parts:
-Clutch
-Brake pads & rotors
-Alternator
-Starter
-Battery
-Radiator & Hoses
-NGK wires ,plugs,Distribtor and cap
-Oil change every 3000
- paging Alarm with remote start
- All 4 Tires are Michelin with 60% even wear on ALL 4
- Everything works A/C , Heat , windows up & Down ,sunroof opens and closes , NO Check Engine Light ,....All lights work Headlights,high beam ,tail light ,Brake lights ,reverse lights
CONS--:Major Issue
--Car runs and drives but when i bought it @ 204k it was having Head gasket( Valve Guides ) issues in Cyl #4 and oil would get to the spark plug and have a hesitation on initial start and would clear up when warm ..then Cyl #3 & #4 Started doing that and then NOW ALL 4 Cyl are doing it so it will need a head gasket/Valve guides ..... i still drive it daily but every 3-5 time i shut it down i have to take ALL 4 spark plugs out to wipe them down of oil and then it would start right up ( PITA ) but I've been doing it for a month now ... Once started it will stay running ... Car is currently registered , Inspected , Insured and i can drive it anywhere...
-- Powerdoor lock on drivers side makes noise when closing ..but works fine
-- Front Suspension squeeks
-- exhaust leak somewhere in the front but not loud but noticeable
-- dings and dents all around and some minor body work on the rear Passenger 1/4 wheel well..
Click Link:
oldschool_250
Feb 10, 2018 01:12 PM
hallgsx91
Mar 23, 2009 11:27 AM
