Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
'04 Accord Coupe V6 6MT noise from left rear
Old Jan 21, 2015 | 10:37 AM
neoteny's Avatar
Default '04 Accord Coupe V6 6MT noise from left rear
I have this noise coming out of the left rear of my car. The noise happens primarily (but not exclusively) when I'm taking a gentle left turn on the road/highway. If I drive straight or in a gentle right turn then it doesn't happen.
The sound is a not very loud but clearly audible low frequency (maybe 10 Hertz) sound of a combination of tapping & cracking.
I've tried putting bunched up plastic bags under the gas door; no change. I've tried putting bunched up plastic bags under the trunk compartment cover on the left side; no change. I've tried to tie the two bowden lines (trunk opening/gas door opening) to other cables; no change.
Is it possible that this noise is coming from the left rear shock absorbers? Is there any cheap & obvious way to test this theory?
Old Jan 23, 2015 | 09:42 PM
lazlong's Avatar
Default Re: '04 Accord Coupe V6 6MT noise from left rear
Have a friend wiggle the rear of the car by hand while you lay on the ground and listen/look.
Old Jan 24, 2015 | 07:29 PM
neoteny's Avatar
Thx, I'll do so when the weather allows.
accordse141
Oct 11, 2011 07:50 PM
motegicivic
Jul 13, 2011 03:42 PM
jason_thaomoto
Aug 10, 2005 01:26 PM
