Obd2 b20 swap
Old Jan 20, 2015 | 08:48 PM
92eghatch13's Avatar
Default Obd2 b20 swap
Hey guys ivy been looking for a while now and can seem to find anything... So I'm gonna ask I've got a 92 hatch I want to swap it's got a d15b7 in it and am planning on swapping a b20 what I can't figure out is I i were to swatch the engine harness to obd2 will I need to switch my dash harness to like a 96-98 one? Any help would be great thanks
Old Jan 20, 2015 | 09:00 PM
tony_2018's Avatar
Fish Twig
Default Re: Obd2 b20 swap
It depends on whether the necessary components are obd1 or obd2.
Old Jan 21, 2015 | 01:12 AM
HondaPartsHero's Avatar
Technical Hero
Just use your factory harness and make the necessary adjustments
-OBD1 to OBD2 distributor adapter (or rewire it yourself)
-reuse your injectors (same 240CC as the B20)
-OBD1 to OBD2 alternator adapter (or rewire using an OBD2 plug)
-if your car has the MAP on the firewall you'll need to tie in the vacuum lines or plug it into the one on top of the throttle body
The rest should plug and play with possibly a little extending
Old Jan 21, 2015 | 03:21 AM
tony_2018's Avatar
Fish Twig
reuse d15 injectors on a b20?
fatsalmon15
Apr 14, 2014 07:40 PM
deucedeuceEK
Oct 8, 2013 07:19 AM
Chilloutdamn
May 13, 2009 05:58 PM
cmasonrun
Jun 13, 2007 04:14 AM
watsvtecEK
Nov 29, 2006 09:33 PM
