93 accord motor mount
Old Jan 19, 2015 | 04:44 PM
bdr_one's Avatar
Default 93 accord motor mount
I need to replace the rear engine mount on my accord I was wondering why it has a vacuum hose on it and what's it for
Old Jan 19, 2015 | 06:51 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 93 accord motor mount
For Automatics the rear mount uses a vacuum controlled diaphragm hydraulic mount. When the car is idling in gear, or a heavy load(A/C) is placed on the engine, the mount disconnects and floats the engine to reduce vibrations into the cabin.
Old Jan 20, 2015 | 09:27 AM
bdr_one's Avatar
Since its bad would there be any kind of jerking or surging going down the road
Old Jan 20, 2015 | 10:12 AM
MAD_MIKE's Avatar
MM Gruppe B
If the rubber portion of the mount broke, hydraulic fluid chamber was ruptured, internal diaphragm no longer worked, or the vacuum controls failed the mount would not stiffen up under power/cruise and would allow the engine to flop about. Check the front engine limiter mount(dogbone) this place a significant part when loading up the mount, if it is damaged it will allow excessive movement as well.
Slowbro
Jan 9, 2015 07:49 PM
webhunter
Jan 7, 2006 03:42 PM
vettman
Jul 16, 2005 12:30 AM
Neldawg
Jan 13, 2004 08:53 PM
sysconx
Oct 6, 2003 03:50 AM
