Replace ECU in 94 Accord with used unit
Need to replace ECU in '94 Accord EX, VTEC, 4 Dr. A/T. Have # from old unit 37820-POA-A51 and have found identical used unit for sale. To install used unit (or new, for that matter) is there any "flashing", "reprogramming", etc. that must be done prior to installation, or do I just install and go? Any help greatly appreciated. Wife's car and have to get it going! Thanks!
Ok, will do that tomorrow. Thanks! Front mount being the one next to the exhaust manifold/bottom middle of radiator right?
__________________________________________________ ____
http://test-king.com/
http://www.test-king.com/onlinecourses/ACT.htm
http://www.hawaii.edu/
Verify the mounts vacuum controls are properly working.
Verify the diaphragm on the mount is not ruptured,
Verify the lever on the mount is not seized.
Verify functionality of the mount and note if there is any difference when the lever is moved.
