94 del sol S rear disc swap question
im in the process of swapping my del sol s's drum brakes with discs from a 94 integra rs, i know i need to pull the trailing arms , prop valve etc. My question is the parking brake, i know the Teg will be too long so im looking for the parking brake cable itself from oreilly's (i work there so stout discount) its showing 2 different cables a rear right and rear left , so does the del sol have 2 cables for it?
thanks
thanks
Er what? Of course it does. Have you actually been underneath your own car? And are you sure you're picking up the right cables?
Hint. Time to get yourself a Helms manual.
