Time Sert thread repair kit
Old Jan 16, 2015 | 08:57 PM
Zaraki's Avatar
Default Time Sert thread repair kit
Has anyone used one of these???
The oil drain hole on the oil pan is pretty messed up on my 94 civic.
Not looking to replace the whole oil pan...
Old Jan 17, 2015 | 08:33 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Time Sert thread repair kit
The hole of the oil pan is pretty thin. I believe time serts are made for closed backed threaded holes i.e. head bolts holes, exhaust manifold stud hole etc.
On an oil pan drain plug hole the usual fix is to tap it larger and use an oversized drain plug bolt.
Old Jan 17, 2015 | 10:15 AM
92ehatch's Avatar
Take the pan off and have a welder weld a nut to it. Easiest way without a new pan
Old Jan 17, 2015 | 10:53 AM
grumblemarc's Avatar
The Grumpiest
They have oversized drain plug kits, or something like that, at many autoparts store.
Old Jan 17, 2015 | 03:32 PM
Zaraki's Avatar
Time Sert 1415C M14 x 1 5 Honda Aluminum Drain Pan Thread Repair Kit | eBay
^ That's the kit I was looking at.
I just bought this car for $1000. It's my beater, runs good but looks terrible. So I'm honestly not looking to put much money into fixing it. It looks like the previous owner stripped the threads in the oil pan and put in a slightly larger bolt.
Old Jan 17, 2015 | 03:45 PM
burnoutboy's Avatar
The Credible Hulk
Ive never used that kit but ive used time serts for everything from head stud holes to transmission cases NEVER had a complaint one from me or anyone whose repair ive done. Ive eyeballed that kit a few times too but havent had a reason to pick one up yet.
Old Jan 17, 2015 | 03:47 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Some Honda/Acura dealers use the Time-sert thread repair kit for oil pan drain plug repair.
Old Jan 17, 2015 | 04:31 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You didn't mention what your car was, so don't know if it's the aluminum pan or the thin walled steel pan.
I don't think there is enough there for a time sert on the steel pans but I could be mistaken.
I personally would just tap it larger and use an oversized drain plug. That is probably the cheapest solution all the way around. Then again I also own a tap and die set.
Old Jan 17, 2015 | 06:14 PM
Zaraki's Avatar
It's a 94 ex w/ a D15B8 motor swap. Honestly, it looks like the oil-pan was swapped so I'm not sure if it's steel or aluminum.
I'll stick a magnet on it later to find out. lol
I just need it to be cheap, and not leak a ton of oil. And I need to be able to use the hole for future oil changes.
Open to anything that doesn't involve removing/replacing the oil pan.
Old Jan 17, 2015 | 06:44 PM
GoldieWang's Avatar
10 Year Member
theres a huge difference in aluminum and steel oil pans. all you need to do is look. the steel pan is most likely black and has a thin flanged lip with it meets the bottom of the block. the aluminum pan is a more silver color and will have a porous texture indicating that its been made in a styrofoam cast.
Old Jan 17, 2015 | 10:17 PM
crazyhouse2011's Avatar
a magnet is a surefire way to know
Old Jan 18, 2015 | 10:55 PM
Zaraki's Avatar
It's a steel pan.
Old Jan 19, 2015 | 05:24 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
It's a steel pan.
Tap and over sized bolt, or new oil pan.
That timesert kit specifically says for aluminum pans (thicker wall, deeper hole) being it has something to grab onto. I'm 99% sure it won't work out well on the steel pan.
Old Jan 19, 2015 | 06:11 AM
tony_2018's Avatar
Fish Twig
This. No point in getting a timesert thats not properly fitted, or won't be properly fitted on.
Old Jan 19, 2015 | 03:29 PM
Zaraki's Avatar
Thanks dude, I appreciate the advice!
sparkyk20eg
K Series
Aug 22, 2018 08:01 PM
jdmda_1.7a
Feb 15, 2011 07:35 AM
1drivinmofo
Mar 10, 2010 05:16 PM
CRXified
18
Oct 31, 2006 04:58 PM
prettyQuik
10
Jun 15, 2004 07:59 AM
