Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Maint. Light turn off
Old Jan 16, 2015 | 01:53 PM
1clean01's Avatar
Default Maint. Light turn off
Firstly, I know the rest procedure for turning off the Maint. Light...
The issue I am having is my Odo/Trip selector does not work; I assume the contact point on the actual cluster is worn out as the car is a 2001. This was not an issue, as the display reads the mileage, until I needed to reset the light.
Today, I figured I would unhook the battery for a few minutes in the hope the light would be rest. No such luck...
Does anyone have any other ideas? Obviously, replacing the cluster would be the proper solution but I am currently on the fence about getting rid of this car. Any help is appreciated, thanks.
Old Jan 16, 2015 | 02:14 PM
slomofo's Avatar
GDD Member
Default Re: Maint. Light turn off
Wow, well that's a new one.
Take the cluster bezels off and see if you can get behind the needle to reset it. No suggestions other than that.
Old Jan 18, 2015 | 04:19 PM
Former User's Avatar
Are you also unable to perform the self diagnosis procedure?
Old Jan 18, 2015 | 04:25 PM
If you can't run the self diagnosis procedure, test the black ground wire for the trip meter at pin B11.
clem151
Oct 3, 2016 05:52 PM
WiedemannC
Oct 22, 2010 04:33 AM
junior_tm
May 6, 2008 08:02 PM
94rs-turbo
Jul 26, 2005 07:39 PM
