98 Civic cranks but won't start
Old Jan 15, 2015 | 04:41 PM
bthom88's Avatar
Default 98 honda civic need help
So I have a 98 civic coupe dx model
New parts I have installed within the last week
Distributor
spark plugs & wires
battery
checked all fuses and main relay
checked Ecu
and crankshaft position sensor
now what had happened was is my car overheated on the highway and it completely died on the off ramp now my battery was very bad to the point where I had to jump my car from another battery when my car died completely on the off ramp of the highway it was smoking out of the engine I had it towed to a tow place and tried to start it up it started up but it was running very rough and shaking the whole front of the car that's when I found out the crankshaft position sensor was bad I took the car to my house and changed all the parts that I have listed out there the head gasket and timing belt and water pump were done a month and a half ago and the reason my car overheated was because my water pump was leaking
now my car cranks over and does not start I have spark and I have fuel I don't know what is wrong and I need help
Old Jan 15, 2015 | 04:45 PM
92ehatch's Avatar
Default re: 98 Civic cranks but won't start
Read the rules sticky. Your thread title needs help.
Also...I'm not reading that awful mess. Some punctuation, even if incorrect is better than none.
Also line spacing like my post is very helpful.
Please try again
Old Jan 15, 2015 | 05:11 PM
bthom88's Avatar
So how should I make it im not gonna type all of that im using a voice to type m
Old Jan 15, 2015 | 05:16 PM
Former User's Avatar
Default Re: 98 Civic cranks but won't start
I edited your thread title.
Check the mechanical timing. If fine, then compression test the cylinders.
Old Jan 15, 2015 | 05:21 PM
bthom88's Avatar
I summed it so it's easier to read
Old Jan 15, 2015 | 05:22 PM
bthom88's Avatar
Ok what if both those thing are good then what would I be looking at is there any other sensors
Old Jan 15, 2015 | 05:23 PM
Also verify that the spark plug wires are installed in the correct firing order on the distributor cap.
Any CEL codes?
Old Jan 15, 2015 | 05:30 PM
bthom88's Avatar
Wires are In the right order and I took all plugs out and grounded them and they all fire
I have a video if you want to see
I even tried starting it with starter fluid
No luck smh
92ehatch's Avatar
Much better
Old Jan 15, 2015 | 05:32 PM
92ehatch's Avatar
No luck smh
This sounds to me like timing as Ron suggested or mechanical damage.
You need to check the timing as suggested
Old Jan 15, 2015 | 05:33 PM
No luck smh
Is spark bright white at all 4 plugs? If so, recheck the the mechanical timing and compression test the cylinders.
Old Jan 15, 2015 | 05:38 PM
bthom88's Avatar
They all spark I will check YouTube to see if they are sparking bright enough tommarro I will check timing I dont have a compression tester is there eny way to find that out
Old Jan 15, 2015 | 05:39 PM
I think you can rent (free) one from AutoZone.
Old Jan 15, 2015 | 05:49 PM
bthom88's Avatar
I will check thank you I will post results asap
Old Jan 17, 2015 | 10:20 AM
bthom88's Avatar
Ok checked the timing belt and everything is on timing I changed the crankshaft position sensor because wire was melted and still nothing
Old Jan 17, 2015 | 05:34 PM
92ehatch's Avatar
As said before.
Check if the spark is bright white and not dull orange
Compression test engine
Old Aug 9, 2017 | 03:31 PM
Kathlene Lynn's Avatar
Felix12013
Jul 18, 2014 07:31 AM
Turbo2374
Apr 23, 2013 08:33 PM
timboscivic
Apr 11, 2012 10:19 AM
feava510
Feb 15, 2009 10:59 AM
