how to get the heater/ac face dash off?
my temperature adjuster is broken and it's stuck to one setting (COLD!). i need to get the face or dash off so i can fix it but couldn't figure out how. if anyone have a helms and can tell me how to get the thing off i'd really appreciate it. thanks.
There should be plenty of posts on this....just search for climate control...
But ill give you the just of it...
Use a screw driver to gently take out the rear defrost and hazard buttons...from underneath the buttons...pull out the buttons and unplug wires..remove two screws from behind the buttons....pull out the unit...slide the heater control all the way to the right (hottest setting)...look underneath and pull out the cable/wire thats attached to the heater control...it should then slide right out!
eggsi619
Nov 7, 2009 07:39 PM
