D16y7 intake manifold compatible with y8 head?
Old Jan 13, 2015 | 10:08 AM
Crosseman's Avatar
Default D16y7 intake manifold compatible with y8 head?
Im swapping a y8 into my 99 civic and im wondering if i can use the y7 intake manifold with the y8. Thanks for all the responses.
Old Jan 13, 2015 | 10:56 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: D16y7 intake manifold compatible with y8 head?
Yes.
Old Jan 13, 2015 | 11:37 AM
HondaPartsHero's Avatar
Technical Hero
Bolt up yes, as far as compatible with your ECU, depends. If you car is auto it'll be fine but if you plan on using a manual P2P ECU then you'll need to convert to a 2 wire IACV and you can not use the Y7 manifold.
Old Jan 14, 2015 | 04:36 PM
Gator417's Avatar
If your car is a manual, you can still use the intake. You'll have to splice the 2 wires fron the harness to your stock connector. Its been a while, but I think you leave out the orange wire. Either way, get some schematics and get after it. PS: is there an advantage to using the Y7 intake over the Y8 or is it just because its what you have?
Gator
Old Jan 14, 2015 | 05:29 PM
Technical Hero
No the 3 wire IACV is not compatible with Y8 manual ECU. Two totally different IACV types. Now if you stay with the Y7 ECU, not sure why you would, but then it would work with the 3 wire IACV on the throttle body.
pnwjdm
Sep 23, 2013 07:34 AM
termite1r
10
Sep 2, 2013 10:29 AM
uindaway
Nov 12, 2012 01:25 AM
actek988
May 1, 2012 12:50 PM
phasewest
Dec 12, 2004 08:57 PM
