Intermittent check engine light for EGR.
Old Jan 13, 2015 | 08:43 AM
SarcasticaLy's Avatar
Default Intermittent check engine light for EGR.
Hey guys,
I need to get a hold of a D series guru. So I have a 92 Civic EG Hatch CX. The CEL is intermittent and resets every time I shut the car off. It'll come on after long periods of highway driving. I checked the code and its the EGR but Ive removed the EGR and cleaned it out and checked the plunger and everything. It seems to be fine. Should I try replacing it? My niece's husband said to just get a 94 ECU cuz it doesn't even look for the EGR but I don't really trust him so I don't wanna go that route. Thanks for reading.
Old Jan 13, 2015 | 05:00 PM
Former User's Avatar
Default Re: Intermittent check engine light for EGR.
Can I assume that you have a Civic VX with the stock D15Z1 engine and P07 ECU? Or is this an engine swap? Post some pictures of the car, engine bay, and ECU.
Old Jan 13, 2015 | 05:17 PM
tony_2018's Avatar
Fish Twig
Please verify engine code and ecu code. Also it is a high chance your egr passageways are clogged so that will need to be clean.
Old Jan 13, 2015 | 06:26 PM
Yes, stock everything. D16. CX model. I've already took it off and cleaned it. Obviously it didn't do anything.
Lemme take some pics for you guys.
Old Jan 13, 2015 | 06:28 PM
You don't have a stock 92 Civic CX if it has a D16 engine and is throwing an EGR code.
Old Jan 13, 2015 | 06:56 PM
Hmm I stand corrected. Far as I know it's a CX. Here's a few pics. Sorry for the crappy pics. It's in my driveway right now. Apparently it's a D15. Smh. Anyway here ya go.
Here's the ECU, appears to be P07. Don't know if you can zoom but I can see the digits;
Engine code;
VTEC-E engine;
Old Jan 13, 2015 | 07:02 PM
Looks like a JDM engine swap.
Post the head code:
https://honda-tech.com/honda-civic-d.../#post48684945
Old Jan 13, 2015 | 07:17 PM
Next locate the components of the EGR system and check whether anything is missing or disconnected.
Old Jan 13, 2015 | 07:18 PM
Jimster480's Avatar
Looks like a 92 D15b from a VTI. But only a head code will tell us for sure. Although the absence of a Double VTEC Solenoid shows that its clearly a single VTEC OBD-1 model from the 92-95 VTI's.
Are you sure its an EGR code? are you using an OB2->OB1 harness or something? Or just using a straight OBD2 harness modded (stupid, but I have seen it).
Old Jan 13, 2015 | 07:32 PM
I just pulled the code with the plug above the ECU. I haven't done it in a long time but I'm 100% sure it's egr code. Did it numerous times. I did the diag tree. Still nothing. I replaced it with a used part. Still same result.
Old Jan 13, 2015 | 07:36 PM
Jimster480's Avatar
Are you using the JDM ECU? Or a USDM ECU? because I dont remember them even having an EGR...
Old Jan 13, 2015 | 07:41 PM
Idk Jimster. I haven't modded anything in the car. The reverse if anything. I just ordered n installed the stock intake. I replaced old parts such as wiper motor, floor mats, window moldings. Stuff like that. Otherwise it's how I got it.
Old Jan 13, 2015 | 07:43 PM
Not sure if it relates but the PO said the MAF sensor was switched out to MAP or the other way around or something. There was a connector near the firewall and I asked why it's not plugged with the other side of it and he said he had it wired up to the MAP/MAF/whichever. Idk
Old Jan 13, 2015 | 07:44 PM
Old Jan 13, 2015 | 07:46 PM
Reset the ECU and do it again.
Convince me.
Jimster480's Avatar
There are no MAF sensors on Honda vehicles... They had a couple cars with MAF's in the 80's from what I remember. Nothing else has a MAF. Honda's are all MAP even in obd1.
Old Jan 13, 2015 | 07:52 PM
I've reset the ECU also. Every time I shut the car off then start it up again whenever, the light is off for avg 10-15 minutes. Putting the kid to sleep. I'll get the head code in a bit. I'll try to get to the diag tree again soon. It's my Friday so I'll try to squeeze some time in tomorrow.
Old Jan 13, 2015 | 09:48 PM
Here ya go fellas.....
Old Jan 13, 2015 | 09:55 PM
P07-1?
Old Jan 13, 2015 | 10:09 PM
P02-1
Old Jan 14, 2015 | 02:43 AM
HondaPartsHero's Avatar
Technical Hero
That's correct for at least Civic/Integra up to 01. Newer Honda are starting to use MAF
Old Jan 14, 2015 | 03:57 AM
Jimster480's Avatar
lmfao really? I know 04 Civic doesn't have a MAF. Maybe past 2005?
What a complete joke Honda has become. They have literally gone backwards in tech to the tune of almost 25 years. They have crappy leaf-spring suspensions also these days. Wouldn't ever purchase one even if it was the only auto mfg left.
What is a P02? I see from the pic that it has VTEC.. Typically those heads were P08. Is it possibly a VTEC-E variant?
Old Jan 14, 2015 | 05:51 AM
The VTEC-E heads are P07-1 that I have seen. I haven't seen a P02-1.
Old Jan 14, 2015 | 06:29 AM
Jimster480's Avatar
you are right, they are p07... So what engine is that?
I honestly have no idea what cast that is. I spent some time googling it and couldn't find anything...
