Testing the Crank Position (CKP) sensor
I tested mine at the distributor on 2k ohms it read 414. Then I tested it at the ecu and it read about 414. Then I put it on 200 and tested the white wire off the distributor. With the red pin on the white and the black to a ground. That went to zero. Then I tried the orange wire from the dizzy and got .384. Does that mean there is a short or is that the correct reading?
enabi
Aug 8, 2002 05:36 PM
