need insight on jdm d15 non v
Old Jan 9, 2015 | 04:14 PM
Ef4doorwagon's Avatar
Default need insight on jdm d15 non v
Assembling my engine... And neither the sohc zc or the d15b2 Crankshaft gear( goes behind the crank pulley) fit onto the crank shaft. They're too big
Do I need to get a d15b7 crankshaft gear and crank pulley?
Old Jan 10, 2015 | 07:01 AM
jlicrx's Avatar
Default Re: need insight on jdm d15 non v
all 88 and some 89 D-series engines have a crankshaft with a 22mm diameter front snout, where the pulleys go on - most 89 and all 90 and up engines have the larger 24mm diameter snout - you need the pulleys from an 88 if your front snout is 22mm diameter
Old Jan 11, 2015 | 09:10 PM
Oh thanks. Guess mine is an 88.
york
Aug 5, 2015 04:22 PM
craigboostedrex
Apr 6, 2011 07:25 PM
James89DX
Dec 29, 2008 06:23 PM
91zSi
Dec 26, 2005 03:31 PM
quis23
Jul 14, 2003 10:40 AM
