Cleaning out the shop and storage! Tons of parts!
Old Jan 9, 2015 | 07:52 AM
BTWPerformance's Avatar
Default Cleaning out the shop and storage! Tons of parts!
Hey guys trying to do a winter clean up and get rid of used and new parts. I have hundreds of more things then what im listing below, this is just off top of my head. If you dont see it listed then shoot me a pm or call/text 256-318-4729 and ill give you all details and pictures! All used parts are tested and work! I will ship anywhere as well and if its new part that i dont have in stock that you need i will drop ship to save you time and money. Also i have all Honda set up's new and can install those in ecu's if needed! Best way to reach is number above since im so busy during the day.
avid-1 16x8 15offset blue in color brand new in boxes $450
integra ceneter caps
99-00 si Tbracket 60$
ef b series Tbracket 50$
hasport b series mounts 150$
b series aftermarket clutch 75$
99-00 si headlights 75$
top feed 750cc with pigtails grams 350$
rc440cc 150$
rc 550cc 200$ with pig tails
99-00 civic grill 30$
gsr shift linkage 75$
ls b series valve cover 45$
b series obd1 alt 60$
b series hydro starter 50 $
Isis t3 top mount turbo 70 trim 200$
obd1-obd2 jumper harness rywire 45$
CS ebrake drift **** lock out buttons new
complete wet nitrous kit 150 shot or less 400$
sparco shift boot new universal black 40$
hks ssqv IV new 50$
ARP acura 1.8 rod bolts new 100$
Hasport new motor mounts 94-01 integra or 92-95 civic b series 290$
dual guage pod may be universal black 10$
Hasport new mounts 96-00 civic 369$
tachometer 20$ autometer no shift light
carbon fiber b series password jdm plug cover 60$
hood pin kit 5$
walboro new fuel pumps 255 in tank 100$
New Prothane bushing kit 96-00 front lower control arm 60$
New Prothane 88-00 civic rear trailing arm bushings 150$
eg auto cluster no tach 40$
new comp clutch for mustang 350$
New BnM short shifter b and d series 70$
92-00 front lips new 60$
Black Vibrant street power muffler 125$
Blackworks subframe brace and lower control arms purple 96-00 350$
Blackworks bumper quick release 31$
Blackworks camber kit 88-00 civic 100$
Blackworks hood risers 29$
Blackworks shifter bushings 12.99$
Blackworks cam seal plugs 15$
Skunk 2 thermal gaskets 40$
Cometic Head gasket 82mm 99-00civic, 94-97 delsol, 92-01 integra 97$
Tons of new vibrant parts clamps, couplers, fittings, etc.
Bazooka sub box with 2 10inch pyles with a amp 100$
New Dsport magazines each monthly issue $8.99
Skunk 2 alpha header for all b series 400$
Wastegate springs
d16z6 good running engine 500$
jdm b16a swap b16 cable trans shifts great no grinds, best one i have ever felt. No smoking from engine, comes with obdo dizzy, 1200$
have tons of heads and blocks
tons of shift linkages and axles
tons of dizzy's, ecu's , TB's, Intake manifolds, IC piping,
starters, alternators, cranks, flywheels, harnesses, interior.
92-95 civic hatch cargo cover 50$
92-95 full rear interior including seats good condition will sale all together in bundle or part out. Just shoot me a text or pm for what you want.
Ef Bseries linkage 40$
also have all new chase bays products!
Old Jan 9, 2015 | 08:20 AM
eg9's Avatar
eg9
Default Re: Cleaning out the shop and storage! Tons of parts!
**EFFECTIVE IMMEDIATELY**
Old Jan 9, 2015 | 09:16 AM
e0325's Avatar
I'm looking for a B16 dizzy,let me know
Old Jan 13, 2015 | 04:14 PM
Kalili22's Avatar
Looking for a D16Z6 head lmk
Old Jan 13, 2015 | 11:03 PM
Tkrizz's Avatar
Do you have the black front and rear carpet for a 92-95 hatch thats in good shape? lmk
Old Jan 19, 2015 | 09:13 AM
Bump more new and used parts in pm or text me 256-318-4729 and ill lyk prices!
Old Jan 19, 2015 | 10:34 AM
roryss024's Avatar
Would you happen to still have a B series starter, obd2a wire harness for b series (pref gsr) or a flywheel debris shield for B series?
Slosc2
Aug 17, 2009 08:36 PM
