Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
06 Accord No Heat & Overheating
Old Jan 8, 2015 | 06:19 AM
rpmeena's Avatar
Default 06 Accord No Heat & Overheating
Hello All,
My 06 Accord Ex-L was having issues this morning. It's extremely cold where I am, about 0 degrees Farenheit. The engine heated up to normal running temperature but the heat continued to blow cold air. I changed to defrost and turned up the temperature. When I did this the engine started to overheat. I pulled over and let it cool down and then I drove a few miles home and the engine ran at it's normal running temperature.
I recently had to have the radiator replaced. This was about 2 weeks ago and the car has run well since. Any ideas what's going on with my car? Any help would be much appreciated.
Old Jan 8, 2015 | 03:03 PM
Lost Again's Avatar
Default Re: 06 Accord No Heat & Overheating
Did you have the t-stat replaced when the rad was done?
Re-check the coolant level,,,,,and I would also look for more leaks - hose connections and that.
luvmihatch
Mar 5, 2013 04:49 PM
Smokey9677
Jun 11, 2011 07:56 AM
vic_houston
Jan 18, 2008 10:39 AM
jboy210
Dec 20, 2007 03:57 PM
95white
Feb 9, 2007 03:36 PM
