iacv f23
Old Jan 6, 2015 | 03:13 PM
sycomajor's Avatar
Default iacv f23
okay i just switch from the f22 to the f23a motor. I switch the intake manifold off the old f22 on to the new f23A. do i still have to block off the Iacv. since i have the old f22 intake manifold on my f23a motor? when i start my car it idles like a mf!!!!!!
PLEASE HEL
P?????????
Old Jan 6, 2015 | 03:32 PM
GhostAccord's Avatar
Default Re: iacv f23
What years are the F22 and F23? A little bit more information about the swap would help!
I would say that you could probably have a vacuum leak between the F22 intake manifold and the F23 head. Or you could have a couple of the sensor connectors mixed up.
Old Jan 6, 2015 | 03:34 PM
sycomajor's Avatar
the f22 was a 95 and the f23a was 98
Old Jan 6, 2015 | 04:16 PM
VTEC or non (F22B1 or F22B2)?
Some of these engines have a system that injects air directly into the fuel injector ports, it's called the fuel injection air control system (FIA). If the intake gaskets and intake manifolds don't match they can cause vacuum leaks. kif you have the intake manifold that is equipped with the FIA ports and the gasket and cylinder head don't or vice versa.... it will cause a leak.
Yankeefandan
Apr 5, 2016 12:12 PM
elmejor
Sep 5, 2008 06:29 AM
drummingpariah
Nov 13, 2007 01:56 PM
JDubbs99Civic
Mar 11, 2006 12:52 PM
who00knows
Apr 25, 2003 01:19 PM
