Hazards/ Signals
Old Jan 5, 2015 | 11:35 PM
Justin Meiring's Avatar
Default Hazards/ Signals
The hazards in my 91 civic dx are not working. All bulbs are brand new, and all turn signals work. except the rear passenger side. When i hit the switch, nothing happens. No clicking. The front passenger turn signals flash quickly indicating a bad bulb, but all bulbs are brand new. (I have also switch drivers side bulb to passenger side and the same thing happens.) Could this be a relay, or should i cut the wiring to that turn signal and get a new wiring assembly for it? It looks like it has been messed with quick a bit, lots of electrical tape.
Old Jan 6, 2015 | 12:33 PM
Fosterryan's Avatar
Default Re: Hazards/ Signals
Maybe check your fuses? I had this problem and it turns out I left a wire exposed in my stereo which grounded out on metal and blew my hazards fuse.
Old Jan 6, 2015 | 12:44 PM
ProjetEF's Avatar
it sound like a bad ground
verify continuity between the black wire and the body (pin your tester in the turn signal connector)
if there is no continuity, ground is bad
hybridnorth
37
Feb 16, 2019 06:13 AM
jacreech777
Lighting
Aug 5, 2016 02:27 PM
superfly23
Honda CR-V & Element
Feb 22, 2016 01:00 PM
92civicGA
Mar 2, 2007 10:22 AM
si90rex
Aug 10, 2006 09:54 AM
