Here a few questions on my 93 Accord
I have a few questions
1.Where can I buy the seals for the IAC and the FITV?
2.The cruise on my Accord dont set ,I set the cruise at 60mph and it drop to 40mph before it kicks in.
3.After my Accord sit for a few days the brake lamp in the dash comes on,then I drive about 5miles turn it off .Restart in goes out,I have replace all the bulbs in the rear of the car'
1 majestic honda should have them
2 adjust ur throttle and cruise control cable to factory specs
3 sounds like a short in the wireing or corrosion in the bulb housing use some electric grease or find what's causing the indicator
1. I got replacement o-rings that fit from NAPA. You can also get full o-ring kits from Amazon for less than $14 shipped (for the metric standard set). Between the standard set and a A/C o-ring set, you should have everything you need. If not NAPA has a few other sizes that they will sell you individually.
Neiko Tools Pro-Grade 419-Piece Universal O-Ring Assortment Set - Metric - Faucet O Rings - Amazon.com
Regarding the brake lamp bulb, there's a switch built into the brake master cylinder cap that checks for low fluid level. The connection to it may be bad. Try unplugging the switch and see if the lamp goes out.
