civic b16a2 swap secondary o2 sensor?
Hi i have a 2000 Honda civic with a b16a2 swap. From what i read i have to extend the secondary o2 and wire it directly to the ecu? If not then how do hook it up?
Its a ex but i have the correct engine harness. The secondary o2 sensor plug is on the cabin harness
Well the way my catalytic converter is set up the o2 sensor hits the shift linkage so it is bent and could be broken but whenever i connect it my spedo fuse blows when it warms up and it throws 3 more codes.
Here’s the pin locations:
OBD2a
2nd 02 Sensor ECU Connector
White Wire TO D14 – Sensor Heater 02 Signal (SH02S)
Green Wire TO D11 – Sensor Ground 2 (SG2)
Black Wire TO A5 – Secondary Heater 02 Control (S02HTC)
Black Wire TO A11 – Power Source 1 (1GP1)
OBD2a
I dont have a D connector. Only A, B and C. Ill probably just use a continuity tester to see where they go. I think i know though
lv6l
11
Apr 8, 2008 01:10 PM
efking1985
Feb 12, 2007 08:31 AM
BlueShadow
Dec 1, 2005 08:10 PM
