H22 CRX inlet manifold options
Hi all,
I have a h22 in a crx using hasport mounts. I also have the skunk2 intake manifold and would like to make it work rather than pissing about with cutting material out of the IAB spacer plate or buying a modified plate. So im wondering if anyone has seen or can post me links to a s2 manifold in a h22 crx? Also how much can the firewall be pushed back? I need a couple of inches extra at most.
Cheers
Cheers
Wont work with H trans into EF chassis. Runners are about 2" longer then stock be into the firewall... better choices Euro R which is 1/2" shorter then stock or Excessive makes a manifold.
