Bad bottle of Argon?
Old Jan 1, 2015 | 04:19 PM
turbojeesx's Avatar
Default Bad bottle of Argon?
I just swapped out a bottle of Argon from a new supplier and I think I may have a bad bottle.
I've gotten a bad bottle once before in the past that made welding aluminum next to impossible. Contaminating the puddle, etc.
This time around, aluminum welds perfect, however I'm getting very dull stainless welds.
My go to setup is a #8 gas lens on a WP20 w/Thoriated 3/32" tungsten @ 17 CFH. This has always produced great results for many years.
I've tried bumping the gas up to 20-25-30 CFH with extended post flow and even added some pre-flow.
Bevels and pipe are clean from the belt sander. The puddle doesn't bubble up any crap - the welds just finish up dull.
Has anyone had a similar situation? In my experience, bad bottles usually can be easily identified welding aluminum...
Old Jan 1, 2015 | 05:09 PM
rvs51's Avatar
Default Re: Bad bottle of Argon?
Sounds like a bad bottle.
Old Jan 2, 2015 | 09:16 AM
SovXietday's Avatar
Are you positive you're actually getting the flow you expect?
Old Jan 2, 2015 | 04:06 PM
turbojeesx's Avatar
Yes, 25 CFH is screaming out of the gas nozzle.
This was also a trans-fill. I'm thinking a bad bottle, but it baffles my mind that AU welds perfectly.
Old Jan 2, 2015 | 04:08 PM
burnoutboy's Avatar
The Credible Hulk
Welding gold? Baller
Old Jan 2, 2015 | 04:40 PM
turbojeesx's Avatar
Whoops, you know what I mean: AL .
Old Jan 3, 2015 | 04:55 PM
itspools's Avatar
I've had my local supplier give me a mixed bottle instead of pure argon and I didn't pay attention till I got to the shop and tried to weld with it. Now I check the label every time and hope that it's not just bad gas or mislabeled.
Old Jan 13, 2015 | 04:43 PM
HardCorps's Avatar
odd that it welds AL fine but not stainless, i got a bad bottle once and it would not do AL at all really, but i guess it could be in what mix you truly have. The bad bottle i had was marked only Argon but it was for sure bad because as soon as we changed it out it went back to welding fine making no changes to the welder at all.
2fast4u831
Welding / Fabrication
17
Nov 14, 2013 09:48 PM
EdsGTI
Mar 8, 2010 06:14 AM
Tjabo
19
Feb 3, 2009 07:32 PM
jchrm80
Aug 24, 2008 07:20 PM
