Help!! Have question about D16Z6
Ok, I have a '95 Civic EX motor, had auto tranny on it, but took it off. I will use a '90/91 Civic SI tranny w/ the motor. Do I use the 95 EX flywheel or use the 90/91 flywheel? Any advices would be appreciated. Thanks.
Moot
Moot
I'm pretty sure you could use either and I heard something about how the 95 clutch may have a slightly bigger footprint.
Yager-
[Modified by ImportHatch, 7:03 PM 11/2/2002]
Yager-
use the 95 Flywheel and pressure plate and clutch disc,.. they are bigger on diameter.. i beleive by 2 mm... just keep the whole kit .. it holds a lil more press than the 4G and has more surface.... cant go wrong with it.... i go tthe whole 93 Si kit... works good so far
Or if you don't have the entire 95 Ex setup, you can use the 90/91 clutch with no trouble. With my setup, I'm using my old '90 Si clutch... Well, actually it's not very old, it only has about 10k miles on it.
So in other words, you can use either one and be okay. But in the long run, it might be better to use the Z6 clutch.
[Modified by MrTodd, 9:47 PM 11/2/2002]
ParistsCP
Oct 7, 2008 06:59 AM
Maxcapacity
Mar 25, 2008 06:54 PM
mario_pic
Dec 31, 2007 11:36 AM
KevronsEG
Dec 7, 2002 06:21 AM
