MA 2004 AP2 Silverstone SC S2000 (Clean Title)
Old Jan 1, 2015 | 10:10 AM
EOE's Avatar
EOE
Default 2004 AP2 S2000 Supercharged (Clean Title)
First Name: Dmitriy
Price:
$20,000 as is.
$18,000 on OEM Suspension & Wheels.
Open to serious offers.
Contact: mbm_marlin@yahoo.com
Details about the Car:
-Brief Description
- Originally an Arizona car so, it was rarely exposed to corrosion. I am the 2nd owner and bought this vehicle in 2006 with 28k miles. I drove it back to Boston in 2008. She is stored away during the winter months. This vehicle has proven to be extremely reliable on 11psi.
http://www.s2ki.com/...-clean-cut-ap2/
-Underbody
No Rust. Excellent condition
-Body
No Rust. Very well taken care of. Very small dent near jack points. Subtle and hard to notice.
-Soft Top
Brand new canvass soft top. Should last longer, more flexible in the cold, looks better.
-Reliability
The following tests were completed prior to supercharging and tune:
Compression Test
Cylinder Leak-Down Test
Valve springs & retainers inspection
Motor Mounts
Cooling System Pressure
04 & 05 S2000 seem to be more/most reliable as they don't have tight exhaust valves.
-Engine
F22 stock motor with 155kmiles
Comptech Supercharger with After-Cooler and large Heat-Exchanger.
E-Manage Ultimate ECU is tuned by well known Giles. Conservative/Safe tune.
SAE Corrected numbers are 350HP/230TQ @ 11psi. Add another 10-15HP/TQ with standard correction.
-Suspension
Bilstein PSS9 Coil-Over System (Very Comfortable) with 9 adjustments. (10k miles)
-Inspection
Stock ECU is retained and E-Manage is used to control 600cc injectors, timing, VTEC, etc. This S2000 WILL pass inspection.
- All other parts on this car are listed below. All are authentic.
| 60mm Berk Test-Pipe | HKS Hi-Power Exhaust | T1R Axle Spacers | Veilside Spoiler | Wedssport TC105N Rims | COBRA Water Pump with Large Heat-Exchanger |
Old Jan 29, 2015 | 04:26 AM
STR8 H8N's Avatar
STR8 to Ignore List
Default Re: 2004 AP2 Silverstone SC S2000 (Clean Title)
ouch
Beezys2k.
Jun 26, 2011 09:04 AM
ThatOneGuy3131
Honda S2000
Jul 10, 2010 06:16 AM
dagle
Northern California (Sales)
Nov 10, 2008 07:36 PM
FA1con
Honda S2000
May 2, 2008 07:01 AM
shutupitsANDREW
Honda S2000
Dec 6, 2004 05:31 PM
