crome tuning, poping with lights off,
Old Dec 31, 2014 | 03:57 PM
rustproof's Avatar
Default crome tuning, poping with lights off,
hello
i tuned alot of cars with crome,
but lately i have some issues with idle,
i do all the usual things, offsets, timing sync, with lights on,
but when i turn off the lights the car starts popping/misfiring like its leaning, but afr's are 13.9-14.2. battery voltage dosnt change alot, when this happens,
spark plug gap is usually .028-.030.
eld is disabled, on all the cars i tune,
any idea?
thanks
Old Dec 31, 2014 | 05:32 PM
PyroProblem's Avatar
Default Re: crome tuning, poping with lights off,
Plug wires? Igniter?
Maaybe try another ecu? Idk. Just throwing random ideas that I've seen do weird **** before.
Old Jan 1, 2015 | 11:42 AM
DC_Legacy's Avatar
Injector Battery Offset. When this is off you'll see different characteristics of fueling when theirs voltage draw from lights or other components that weigh on the battery.
You stated the battery voltage doesn't change much but is the offset tailored for you injectors?
Old Jan 2, 2015 | 11:59 AM
boosted k20's Avatar
put on all electrical loads i.e. lights, rear defroster, heat and adjust the battery offset tables. I have tuned many cars on crome and i never had that issue once the battery offset tables are adjusted
Old Jan 3, 2015 | 05:37 AM
Muckman's Avatar
Moderator in Chief
You can even unplugg the alt from the battery so you can tune the battery injector offset table on battery voltage and below. AFR should not waver from just a change in voltage.
Old Jan 5, 2015 | 08:45 AM
theYBLEGAL's Avatar
Loved
In my car with a P30, Crome wouldn't detect the battery voltage correctly. It wouldn't detect over 14.1 very well.
I would use a multimeter to verify the battery voltage isn't fluctuating vs what Crome is telling you through datalog.
It's probably offsets that's the cause, but it may be Cromes fault.
Now that I've switched to Neptune, battery offsets work as they should, and voltages are detected correctly by the ECU.
that_boy_sammy
May 18, 2011 04:55 PM
elementalpuck
Honda Civic (2006 - 2015)
Aug 21, 2009 10:59 AM
nemesiskrp
Apr 8, 2009 12:42 AM
goodOLdayz
Oct 12, 2005 11:06 PM
