Clock Backlight not working.
Old Dec 30, 2014 | 12:54 PM
Canucksfan101's Avatar
Default Clock Backlight not working.
Hi,
I have a Honda Accord 2002 se 4cy 4dr
I bought a ipod interface to hook up to my oem radio and after reattaching the dashboard and the parts I noticed that the hazard switch light and clock Backlight stopped working. I thought it was the t3 bulb so I replaced it. However, that did not fix the problem. Now I'm wondering if it could be related to the fuse? If so what fuse should I check? Interior lights?
Thanks in advance!
Old Dec 30, 2014 | 04:13 PM
belairbrian's Avatar
Default Re: Clock Backlight not working.
the clock illumination is on fuse 9 of the underdash fuse panel. It is powered anytime the key is in run. The hazard light is through the headlight switch (dash illumination)
Old Dec 31, 2014 | 01:09 PM
Okay, which fuse number would the hazard light be ? Also how would I tell if my fuse needs to be replaced.
Thanks!
Old Dec 31, 2014 | 02:02 PM
masospaghetti's Avatar
I think the clock has a mini bulb in there to provide illumination, it might be burned out.
Old Dec 31, 2014 | 03:02 PM
If the rest of the dash lights are working then the hazard switch isn't a fuse problem they share a fuse and are controlled by the instrument light dimmer.
as for checking fuses
Ryanb525
Jul 27, 2014 12:17 AM
carmanvti
Lighting
Oct 17, 2009 10:18 PM
traxxasx
10
Aug 10, 2009 01:28 PM
I8ayellowcrayon
21
Sep 1, 2005 01:34 AM
guywitaDA
Apr 21, 2004 09:58 PM
