ZC Blockr & 89 Teg Head??
You use the cam gears that match whatever block you're running.
ZC block = ZC cam gears
The ZC gears gave 34 teeth. The Integra gears have 40. You are correct in that you cannot mix them!
Sonny
Sonny
What if I use a DOHC ZC head on a 89 Integra block, will that work? Cause I am thinking about getting a complete block from the junkyard. My block is messed up, and I want to rebuild it. I have a perfectly good ZC head. Would the 89 Integra block work though?
Sonny
mating a d16a1 block with a zc head would be a good setup if you live in cali.. the legal stamp on the block. has anyone done this, and what would be the power output?
D16A1 block, D16A1 head --> 1st gen = Yes, 2nd gen = NO
D16A1 block, ZC head --> 1st gen = Yes, 2nd gen = NO
(Black Top) ZC block, ZC head --> 1st gen = NO, 2nd gen = Yes
(Black Top) ZC block, D16A1 head --> 1st gen = NO, 2nd gen = Yes
The brown top ZC uses the same mount points as the D16A1.
Sonny
I belive you can just swap over the ZC Crank gear on the D16a1 and still use the ZC cam gears... but you will need to use a ZC T-belt part # 14400-PK2-004
Jeff frank
Jeff frank
Well the only reason I would even contemplate this is because of my ZC block i have, has a stripped bolt hole in the block. Its a head bolt hole. I want to turbo this motor when I rebuild it, so I dont know what to do. If it would be easy to just buy an 88-89 integra block from the junkyard, they are a plenium here.. Every corner there is one, so I could get the complete block for like 50 bucks. Or try to find a shop to rethread the head bolt threads... Not sure whta to do, anyone ever had this happen?
You CAN put a 86-89 Integra block into a 2nd gen CRX, but it really is a hack job (to put it nicely). The mounts are in completely different places and the one guy that I saw who managed to do it had to leave a couple of the tranny bolts out...not good.
Fix your ZC block. Have a machine shop drill out the messed up hole and install a helicoil. Then use ARP headstuds for your turbo buildup.
Sonny
Okay well I will try something. I found one place that owuld do it for 50 bucks. Would helicoil hold up good? Or if the motor gets hot will it back out the bolt?
Gt limited(jdm approved)
Jun 26, 2011 02:49 AM
