turbo my 06 civic ex??
Hey guys i dont kno if this post should be here or not.. but i bought my bros 06 honda civic for 2k.. and decided if i found a cheap turbo i would throw it on.. well i found a d series turbo..this is wat the ad says:
D series turbo kit custom 450cc orisis injectors. Brand new manifold and brand new 57 trim turbo. 38mm wastegate Apexi blow off valve...
Now will this fit on my civic? Im mechanically inclined build alot of my own stuff but new to hondas.. any help would be awsome.. even someone who knos what there doin contact info lol.. thanks fellas
On 2nd thought dont even bother replying again.. i dont need your dumb answers from some jackass that sits on here to talk **** about other people.. i read some of your other posts.. your what they call a *******.. i dont care if you kno anything or not.. dont ******* coment on my thread if your not willing to give advise.. im not looking for a ******* "google it" answer.. or a "wow".. just shut your mouth and let someone help me rather thanvtry and degrade my question.. ******* punk
Ok, to start, any turbo option is a gamble without the proper tuning. It is an R18 engine I would presume, so a Hondata tune would be required for your ECU.
You will need help, professional help. The turbo is only apportion of the build.
If you plan on going light, stock internals and all, low boost. You will need:
Fuel injectors, fuel rail with pressure gauge, better ( larger) throttle body assembly, intake plenum, head gaskets, exhaust manifold that accomodated the turbo setup, catalytic converter delete exhaust or new exhaust that accomodates the turbo dump and cat.
If you want to go big, you will need to rebuild the engine with upgraded internals and that requires a suitcase full of Benjamins.
Stay light - 8 lbs or less of boost and enjoy the rush. But turbo builds are a lot of work.
I grazed the surface here. Get help from a good shop on this if you're serious.
Turbocharging - 8th Generation Honda Civic Forum
Do you think this is an alternator you just bolt on? And do you think you were actually helped with that reply? Absolutely not. 8lbs of boost? WTF? PSI doesn't mean dick. And anyone telling you to base your turbo build on a measure of PSI without knowing the turbo and your power goals (you do have goals other than slapping on a turbo, right?) is doing more harm than good.
BTW. Public forum. You don't get to dictate what get's added to an ignorant request for spoonfeeding on a most complex topic that you CANNOT get an answer to in just a reply on a forum. All you helpless noobs crawling out of the woodwork lately is just downright ridiculous.
Here. lazy guy. As if no one has ever asked about this topic.
