need to know which wires for each sensor
Old Dec 26, 2014 | 06:04 PM
Ef4doorwagon's Avatar
Default need to know which wires for each sensor
So before putting my manifold back... I was looking thru all my connectors making sure they're all there. I have the tps and map sensor aside. I believe the iacv is a green plug with yelw blue/ blk yelw wires. There's 2 plugs left I know one of them is for the iat sensor, but Idk about the other. Both are 2-wire connectors- one is orange wire and yelw blk; the other connector is orange ylw and green blk. Which is for the intake air temp sensor and what does the other plug do?
Old Dec 27, 2014 | 10:48 AM
jlicrx's Avatar
Default Re: need to know which wires for each sensor
88-91 sensor wire colors:
EACV (IACV) - 2-wire connector (if car was DPFI, the connector is green) - one Blue with Yellow stripe and one Black with Yellow stripe
IAT - 2-wire connector - one Red with Yellow stripe and one Green with White stripe
Tandem Control Valve (on DPFI only) - 2-wire connector - one Solid Orange and one Black with Yellow stripe
TPS - 3-wire connector - one Yellow with White stripe, one Green with White stripe and one Red with Blue stripe
MAP - 3-wire connector - one Yellow with Red stripe, one Green with White stripe and one Solid White
FICV (Fast Idle Control Valve on 89-91 D16A6 only) - 2-wire connector - one Black with Yellow stripe and one Solid Blue
Cooling Fan Switch - 2-wire connector - one Yellow with Green stripe and one Solid Black
TW Sensor (Coolant Temp for ECU) - 2-wire connector - one Red with White stripe and one Green with White stripe
Temp Gauge Sending Unit - 1-wire connector - Yellow with Green stripe
Oil Pressure Sending Unit - - 1-wire connector - Yellow with Red stripe
Old Dec 27, 2014 | 12:26 PM
Ahh OK that clears things up, the orange wiredconnector is not uused in mpfi, I think.
Also there's another wire coming from the harness that's on the passenger side shock tower,its a bblack and white wire with a butt end connector, what's that go into?
Old Dec 27, 2014 | 03:24 PM
jlicrx's Avatar
my guess is that it goes to the starter - only thing I can think of that is Black/White
Old Dec 28, 2014 | 06:19 PM
sstupid's Avatar
10 Year Member
This is the best thread......ever.
Old Dec 28, 2014 | 07:48 PM
jonGSR's Avatar
I agree, especially with the location it is in.
Old Dec 29, 2014 | 03:08 AM
rd91sib18c5r's Avatar
Looks like starter wire.
Ryan559
Sep 2, 2012 08:46 PM
scatterbrain756
Dec 28, 2010 12:33 PM
tacosandbeans
Sep 20, 2010 10:44 AM
Kahuna9889
Apr 5, 2009 05:57 PM
