95 integra steering rack into a 93 civic. will it work ?
OK i have a friend who has a 93 4 door civic and he needs new cv axles I am going to help him do the work since i have done the axles on my 95 civic. while we are in there he wants to put a new steering rack on and wants to put this 95 integra rack on it is power steering the and so is the integra rack. my question is this will the integra rack bolt in or is there modifications that needs to be done and will the power steering pump be able to pump enough for that rack i have heard that the integras steering ratio is tighter then the civics. will there need to be new lines maybe even custom lines due to the length ? does any one know anything about this and can help my out with some knowledge it would be greatly appreciated.
Google. 10 seconds. With pics.
Civic Steering Rack Swap | Importnut.net
after i posted this I went to the google machine and found the exact same article but i was still hopeing for some info from someone who has actually done this swap before just incase there is something missing nothing is better then some first hand experiance ya know
OMG. There's pictures. If they took the time to make a DIY with pics then it's usually a good bet that it's good to go.
Just to add you need the integra resorvoir too, even if you already had power steering. I found out the hard way. The civic pump and the '94 - '97 Integra pump are identical.
Best advice I've gotten here yet cuz we both have OCD and can't stand not finishing a job cuz of something so dumb.. I'll scoop that up after work Monday. Thanks
DexterThEG
Dec 12, 2006 06:26 PM
