CA Ft/fs PRICE DROP 2002 turbo RSX monter 2k miles on motor 650+++whp!!!
Time to get rid of one of my toys but I need a 4 door car I will trade for a tsx,g37, TL or any good 4 door car in the category as the cars above car must have under 70k miles. My car is a 2002 type s no corner where cut and best parts where purchased car block was put together by Anthony @ RS machine and tune by Bubba car made 450whp @10psi on 91 pump and on c16 it made way over 650 there is way more in the engine,turbo kit, fuel system and supporting parts than 15k it's a steal. Motor is healthy with 2k miles on it.
Comes with GPS tracking and car disabling capabilities also if the alarm goes you are sent a notification 1400.00 system.
Car was just updated to the newest version on Kpro version 4
Price:12.5k
Contact: pm me but for quicker response text me (562)761-4998
Engine:
Original k20A2 86mm Sleeved block my RS Machine
Custom crank: k20a2 crank was machined to use Integra GSR
Rods when doing this it gives you a wider rod bearing.
Manley Turbo Tuff Rods
Custom Arias Piston 86mm
New OEM oil pump
New OEM Timing Chain
New OEM Water Pump
New OEM Timing Chain Guides
New OEM 09 TSX Timing Chain Tensioner
New OEM oil pump Chain
New OEM Civic SI Longer upper chain guide (more coverage over the cams)
Circuit Heroes Lower chain Guard (Zero timing jumps)
Head:
Original A2 head
Minor port work
New Valves
New OEM Valve Seals
Supertech Dual Valsprings
Supertech Valve spring seats
Supertech Valve spring Retainers
Supertech Valve Guides
Turbo Kit:
Garrett T4 GT3582R
Custom Built Sidewinder manifold
3” downpipe
2 Tial 44mm Waste gates
2 Dump Tubes (right behind Firewall)
2 ½” Hot side intercooler piping (polished)
3” Cold side intercooler piping (polished)
Tial Blow off Valve
-6 Black steel braided turbo water lines
Vibrant performance Intercooler
Fuel System:
Golden Eagle Fuel Rail
ID 1000cc Fuel Injectors
Fuel Lab Fuel Pressure regulator
Marshall Liquid filled Fuel Pressure gauge
AEM 320lph In tank Fuel Pump
Bosch 044 fuel pump ran inline
-8 Vibrant Black steel braided fuel feed hose
-6 Vibrant Black steel braided fuel Return hose
Inline -8 summit Fuel filter
All Russell Black fittings
Misc.:
Hondata K-Pro Verision 4 just updated
Hondata Boost by gear
Hondata 3 Bar Map sensor
Skunk2 Intake Manifold Shaved and Polished
70MM throttle Body
Skunk2 Mega Power RR 3” exhaust with V-band
Hybrid Racing Power Steering and AC Delete
Billet Motor mounts
Push lock Vacuum Fittings
OEM Type r Valve cover Candy Apple Red powder coat
Timing Chain Cover Powder coated in chrome
Powder coated Engine brackets
Power Steering Delete
All AC and power steering parts are available
Replace all engine and transmission bolts
with Stainless Steel Allen Head Bolts
Relocated underwood fuse box
Relocated battery in the trunk
Transmission:
OEM Type r LSD
2006 rsx type s gear set with all new bearings
Competition Twin Disc Clutch
New OEM Clutch Master Cylinder
New OEM Clutch Slave Cylinder
Steel braided clutch line
GM Synchromesh Tranny Fluid
Interior:
OEM front Red Recaro Seats
Oem Rear type r seat
Oem Red type r Carpet
Oem Red type r Floor mats
Oem Type r Door sills
Oem Red Type r Door Panels
Oem Type r Center console
Oem Type r Hand brake
Oem Type r Momo Steering wheel (with working
Cruise control button and Air bag)
Oem Type r Gauge Cluster
Oem Type r sun visors
Autometer 2 gauge pillar pod
Autometer Cobalt series Boost gauge
Autometer Cobalt series oil pressure gauge
Exterior:
Oem Type r headlights
Carbon Fiber type r lip kit (front is poly urethane)
VIS Carbon Fiber Trunk
05-06 trunk small trunk wing
OEM wind visors
OEM type r front and rear emblems
Wheels & Brakes:
Volk TE37 Time Attack edition 17”
Front tires are Toyo R888 255/45/17
Slotted front rotors
Suspension:
Tien Flex with upgraded swift Springs coilovers where revalved for new springs
Tien EDFC
EMracing Trunk reinforcement bars
C- Pillar bar
Price:12.5k
Engine:
New OEM oil pump
New OEM Water Pump
Head:
Original A2 head
Minor port work
New Valves
New OEM Valve Seals
Turbo Kit:
Garrett T4 GT3582R
3” downpipe
Tial Blow off Valve
Fuel System:
Misc.:
70MM throttle Body
Billet Motor mounts
Transmission:
OEM Type r LSD
Interior:
Exterior:
OEM wind visors
Wheels & Brakes:
Suspension:
Tien EDFC
C- Pillar bar
Frame has 120k the tranny has about 2k miles on it. I don't have any Dyno graphs as I usually don't really care what power it makes as long as it's running right and I didn't think I would be selling the car so I didn't get a print out.
Please see here: Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
