coil melted
so i have a 90 wagovan with a d15. today i was doing a full tune up i pulled the dizzy cap and the spring on the coil was melted into the cap, and part of the coil was melted. what would have done this? im still surprised it was running lol
Wrong part name. You mean distributor cap. I had the same problem. It's melted but current can still flow through it as long as it touches the rotor. Coil is the square thing mounted on the distributor.
The bearing in the dizzy causes it, as the bearing goes out, the shaft stops spinning straight and begins to wobble causing the rotor to hang up
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
it can also be caused by having a bad connection at one of your plugs or a wire, voltage in the coil builds a lot higher then it's supposed to and can arc through the insulation on the windings, happens a lot when people try to check spark by holding a wire near the engine on these, or a wire is off,
Or.
Take pic > put on your computer > upload to photobucket > copy/paste the [img] code from photobucket into the post. Google is your friend.
dave n
Nov 20, 2013 10:41 AM
ParistsCP
Feb 29, 2008 09:00 AM
