01 Accord deck lid holding water
Old Dec 24, 2014 | 07:01 AM
spdkilz911's Avatar
Default 01 Accord deck lid holding water
I just bought a 2001 Accord for my daughter. After it rains or I wash the car, water is getting trapped in the deck lid. When you raise the deck lid water pours into the trunk (a lot) from a couple openings on the underside of the deck lid. I have searched with no luck. Maybe there is a drain that is clogged?? Hope this sounds familiar to someone. TIA
01 Accord
210K miles and going strong
Old Dec 24, 2014 | 08:34 AM
lazlong's Avatar
Default Re: 01 Accord deck lid holding water
Pull the deck lid out and watch it while someone hits it with the hose.
If you have the moonroof then there should be a drain hose going down each of the rear pillars.
Old Dec 24, 2014 | 10:50 AM
spdkilz911's Avatar
Thanks, it does have a moonroof. I will check those drains
Old Dec 26, 2014 | 07:51 AM
MAD_MIKE's Avatar
MM Gruppe B
If the trunk has a wing/spoiler, verify that the attachment bolts are still sealed to the lid.
Verify the taillights are tight and the seals are correctly installed.
Verify the taillights are not leaking.
With the deck-lid open, check the bottom edge, there should be a couple of drains on the inner structure, outside of the trunk seal. They may be clogged with gunk.
Old Dec 27, 2014 | 06:26 AM
spdkilz911's Avatar
Thank you, I will try those as well! No rear spoiler, but the others are possibilities.
Baskervi
Jun 10, 2020 08:03 AM
Jpluck09
Jan 12, 2009 02:41 PM
market525
Oct 1, 2008 09:04 PM
rickytz7111
Jan 18, 2007 06:28 AM
fleastang
Mar 30, 2005 03:14 AM
