Hood Cable disconnected
Old Dec 23, 2014 | 08:43 PM
user122414's Avatar
Default Hood Cable disconnected
Hello, first time poster here.
I have a 1991 Honda Civic STD. The hood release cable has become disconnected and I am having trouble figuring out how to reattach it.
I've removed the front bumper and located the disconnected cable.
Does anyone have a diagram/video/explanation of how to put this back together, or at least manually release the hood? Thank you.
Old Dec 24, 2014 | 03:46 AM
James89DX's Avatar
Default Re: Hood Cable disconnected
Looks like it's still connected to me, just stretched out and full of slack now. Is it still connected at the interior pull lever?
Old Dec 24, 2014 | 07:05 AM
user122414's Avatar
So that square bracket with the circular hole is the mechanism which the ball catches when you pull the interior lever... I see.
I couldn't get it to budge with my hands (I didn't want to force anything and break it), I just assumed it was a bracket which guided the cable to another connection or something.
The cable is connected to the lever in the car, but it must be broken/really stretched out somewhere in the middle. I will try do something like this until I can get a new cable:
Should I be able to press that square bracket with a screw driver to open the hood? Maybe the cable stretched out because that bracket is stuck?
Thanks
Old Dec 24, 2014 | 07:59 AM
James89DX's Avatar
Yes that square bracket with the round hole gets pulled toward the passenger side which releases the hood. If you can push/pull it with your hand or a screwdriver or something you'll accomplish the same thing
Old Dec 25, 2014 | 12:19 PM
user122414's Avatar
It was stuck good, but I got it to pop. Here's a good video of the mechanism someone pm'd me. Thanks everyone.
Old Dec 27, 2014 | 09:42 AM
zrickety's Avatar
Hope you are putting on a new cable, it's a pretty easy fix.
FeelTheBass
Feb 8, 2015 09:42 PM
TanEJ1
Sep 28, 2014 06:01 AM
mortificationrock
Nov 20, 2008 08:56 PM
DsMWookie
Sep 14, 2005 09:04 AM
91ED7Si
Jun 4, 2002 05:25 PM
