stuck with obd1 ls swap 99 civic
Old Dec 23, 2014 | 10:21 AM
poloboy4's Avatar
Default stuck with obd1 ls swap 99 civic
hello h-tech members I have a problem with a obd2b 99 civic I have its a Canadian sedan anyways I have I obd1 ls in it. did the swap my self I did the iac fix and distributor jumper harness ... the car starts and shuts off with very light throttle I cant give it much gas or it bogs. I have a p75 ecu with it. ( I rewired my dizzy plugs (Canadian plugs are so different) so im running obd1 alternator and distributor obd1 injectors. I have code 10-20-41 (did the green plug check engine light flash).. im very stuck cant figure out why I cant drive it or give it gas I have also tried unplugging tps and map and it lets me rev it more but to around 3500 rpm.. sorry for the long post also I have a obd2b to obd1 jumper.
Old Dec 23, 2014 | 02:11 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: stuck with obd1 ls swap 99 civic
How did you wire the alternator? Check fuse 15 under the hood. How did you wire the IAT as the connectors differ between obd1 and 2?
2000ITR#1207
13
Mar 17, 2010 07:49 PM
supra-n-civic
Oct 21, 2009 06:05 PM
deemy72
May 26, 2009 06:51 AM
NJcoupe
Northeast (Sales)
Feb 12, 2006 09:29 AM
Civic
Jun 7, 2003 08:55 AM
